Author Topic: 22re closed loop vs open loop.......  (Read 6828 times)
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« on: Jul 29, 2008, 10:14:11 PM »
I'm going to get around to installing a vacuum gauge....  (watch it for better gas mileage)
I was wondering at what vacuum level the ECU goes out of closed-loop mode and goes into open-loop for power enrichment so I can try to avoid open-loop mode?
Or inversely,  how fast can I accelerate before it goes into open-loop mode.....   ;)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Fearless-Yota
  • Male Posts: 5
  • Member since Aug '08
Re: 22re closed loop vs open loop.......
« Reply #1 on: Aug 02, 2008, 08:12:25 PM »
the computer goes in and out of closed loop due to the O2 senor activity. The O2 works strictly off of heat. Later model  vehicles has O2 heaters to keep the car in closed loop. Closed loop should be your best bet for fuel milage as the computer makes fuel trim adjustments off of ECT, MAF, O2, and TPS. Open loop the computer ignores most of those
Fearless-Yota
  • Male Posts: 5
« Reply #2 on: Aug 03, 2008, 09:51:33 AM »
Vacum has nothing to do with it. Strictly O2 senor activity
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #3 on: Aug 03, 2008, 10:33:25 AM »
and eng. temp.
JamesD
  • Member since Dec '06
« Reply #4 on: Aug 03, 2008, 06:46:54 PM »
Computer uses engine temp to determine when going from open to closed loop if everything else is working properly. Just install your vacuum gauge and go from there.
James
Quote
Sharon-It is odd how society sees things. Let's say a guy sleeps with all these girls, "he's the man!" or a stud but if a girl does, she's a total very *friendly* person or sleeper. Is society sexist?
Quote
Brandon-Well think about it this way. If a key can open a bunch of locks, it is viewed as a master key and is awesome to have but if a lock is opened by a lot of different keys, well thats a pretty shitty lock if you ask me.
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #5 on: Aug 03, 2008, 07:06:17 PM »
emsvitil,
What would be far more useful than the vacuum gauge would be a fuel mixture gauge.
I run an ooooolllllllllllllllllllllllllllddddddddddd  SplitSecond ARM1 Air/Fuel meter found at the following address:
http://www.splitsec.com/products/airfuelmeter.htm
It is very small, like only 2-1/4" wide by 3/4" tall, and is light enough to be mounted to a dash pad with velcro.
I've ran this meter for many, many years on my MR2 with the stock '87 4A-GE engine and with my '91 JDM 4A-GZE engine, and it is currently operating on my '95 3RZ-FE in my truck.
When I have my OBD-II scanner plugged in to my laptop and monitoring my fuel mileage, I can watch my split second gauge above go from rich-to-lean-to-rich-to-lean-to-rich-to-lean... and I'll be making 19-21 miles per gallon at the scanner screen (cruising at normal loads under a closed ecu loop).
Then when I slowly begin rolling into the throttle, I'll see my fuel mileage drop to about 17-18 mpg --the gauge still going lean-to-rich-to-lean-- and then all of a sudden, the split second gauge will go straight to full rich and my mileage will instantaneously drop to 12-13 mpg.
So when I check my mpg, if I averaged down like 17 or 18, then I must have been heavy on the throttle. But if I average upwards to 20-21 mpg, then I must have been driving like a grandma -- one who keeps the ecu in a closed loop.
I also have a vacuum gauge hooked up in my truck, and I do NOT use it for fuel mileage considerations. I use it for engine load considerations.
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #6 on: Aug 03, 2008, 08:41:45 PM »
Well,  I have a vacuum gauge which I got on a clearance sale, can't use a scanguage because it's not OBDII, and don't have the money for a A/F meter...............
Just wanted to try to use what I've got...............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #7 on: Aug 03, 2008, 08:44:33 PM »
Actually, BigMike you may be able to answer the question even though you don't have a 22re......
When the mileage drops and the A/F meter pegs,  what's the vacuum gauge read?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Administrator
  • 511:1 Club
« Reply #8 on: Aug 04, 2008, 10:53:43 AM »
In general, this will vary between engine to engine mainly based nominal power output, load or drag of vehicle, and valve overlapping (camshaft(s)).
Specifically speaking for my engine, recalling from memory as best as possible, if I am running through the gears accelerating from a green light, then it will go open loop at 5 pounds vacuum and less. If I am cruising on the freeway, then it will go open loop in 5th gear on a flat road with no headwind if the vacuum drops below about 12 pounds. In 3rd and 4th gears, depending on the rpm (higher rpms develop more vacuum with decreased throttle), it will go open loop more towards 8 pounds and below.
Cruising on the freeway in 5th at 70 mph, my gauge reads 15-16 pounds vacuum. So I have about 3 to 4 pounds of vacuum to "play with" if you will, before it hits open loop.
And when I say "pounds vacuum", I am referring to millimeters of mercury vacuum :thumbs:
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #9 on: Aug 04, 2008, 02:54:04 PM »
Weird about 5th being different....
How does it know it's in 5th?
Wonder if it's more a function of the TPS........
thanks
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Administrator
  • 511:1 Club
« Reply #10 on: Aug 04, 2008, 11:20:45 PM »
No, no, the thing is about engine load.
In the figures above, 5th gear is assuming freeway speed, or about 70 mph. And there is far more of a load (wind resistance, rolling friction, losses) at 70 than compared to say 30 mph in 3rd gear. Also, I am more likely to be above 2,800 rpm in 3rd gear than compared to that in 5th gear at freeway speeds, which means I am more into my power band in the lower gears (power band of my 3RZ kicks in hard around 3,100 rpm).
More power + less load/resistance = less load on engine = longer stay in the closed loop :thumbs:
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #11 on: Aug 06, 2008, 05:36:56 PM »
Temporarily mounted the gauge (used one of those big black paper clips) without lighting......   :cheese:
Doesn't take much throttle to get it down to 0.    And just a slight change in foot pressure to keep it above 10.
Might have something here to improve mileage   :yupyup:
BTW,  there's another check connector in the engine compartment that's useful.    Single wire, round connector with rubber cap on it.    It's in the same vicinity as the 2 that are plugged into the fender.       It's a direct line to the O2 sensor.   So you can use a digital voltmeter as a cheap A/F meter for temp testing.     Readings jump all over the place when in closed loop mode, but become steady and high when in open loop......
With the voltmeter, I should be able to see under what conditions it goes into open loop, and the corresponding vacuum level.......
 :yesnod:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #12 on: Aug 06, 2008, 08:37:53 PM »
Keep us informed, I am interested.
emsvitil [OP]
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #13 on: Aug 10, 2008, 07:40:18 PM »
Well so far, a vacuum gauge on a 22re seems to react like an on/off either/or switch.......
Doesn't take much throttle to zero out the gauge.   (little 4-banger moving 2 tons around)
As the EFI system doesn't use a MAP sensor, I think the decision to goto power mode is based more on the TPS.........
I'm breadboarding an  A/F meter with odds and ends I already have , plus some cheap pieces from Radio Shack to learn more........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Last post Oct 19, 2005, 07:24:56 PM
by Loosekannon
Last post Oct 22, 2005, 11:09:54 AM
by nowhitefenders
Last post Dec 24, 2005, 05:09:30 PM
by Ramrod
Last post Apr 19, 2013, 11:16:07 PM
by TundraFun
Last post Apr 10, 2014, 08:53:11 PM
by emsvitil
