So i finally got around to installing my aussie locker. I checked everything the instructions asked, put everything mack in the same order,Back lash is fine etc. With the locker in my axle housing, axles in and tires on i notice it seemed i had a huge amount of backlash, So i took it all apart and it was fine. still wondering why it did this a grabbed a short side inner and plugged it into one side of the diff and grabbed it with channel locks to simulate the weight of a tire. The locker seems to move inside the carrier until it hits the cross pin. Is this movement normal for a locker.when it was in the housing with the axles i could rotate the pinion about 1/8 or so rotation before the wheel began to spin.
SO basically I'm asking if lockers like an aussie have play between themselves and the cross pin, translating into more pinion movement before a tire rotates.
