Prado Transmission to a 1994 Runner?
Started by toy4x4il, July 27, 2004, 11:23:14 PM
toy4x4il
Hi
1.I can put my hands on a 2000 transmission & T-Case from a 2000 Toyota Prado 3.0 Tdi. Will it fit my 1994 automatic 3VZE 4Runner and let me finally install a crawler?
2. Is it possible to convert the same 4 runner to manual transmission using the transmission and T-Case, Clutch, Booster and pedals from a 1996 solid axle 2.4 diesel Hilux? :driving:
Thank you
Ron
Tel Aviv - Israel
We learn but die stupid.
Marlin
We do not have the 3.0 Tdi ? engine over here.
Does the trans have a chain or gear driven t/case on it?
As long as the 94 runner and 96 solid axle trucks share the same front end sheet metal body parts, then the pedals ect., should work just fine.
Marlin
