Author Topic: a/c tech help me please.......  (Read 1902 times)
4-lo
  • Turtle Points: -80
  • Male Posts: 752
  • Member since Dec '05
  • build tonite crawl tomorrow
« on: Jul 09, 2008, 04:47:25 PM »
its a 95 v6 runner... a/c works whenever it wants too... when you start the car cold the a/c works fine i mean ice cold..  after a while the a/c is dead then you'll start to smell something sour...and warm air start to flow through...there is no leak cause it works everytime the truck is start up cold and the only time is when the car is warm..
any suggestion anyone...
this site helps alot of us guys and i believe in you... :therethere:
keep up the work marlin + crew... :clap2:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: a/c tech help me please.......
« Reply #1 on: Jul 09, 2008, 05:26:21 PM »
vacuum line
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #2 on: Jul 09, 2008, 06:18:29 PM »
Check and make sure the AC clutch stays engaged  when it starts to blow hot.
TRACKER
  • Turtle Points: 4
  • Male Posts: 442
  • Member since Sep '06
« Reply #3 on: Jul 09, 2008, 11:52:43 PM »
is your electric fan working?  sound like your ac got hot and built too much pressure  and the high lo switch cut off the ac .    or go get cheap ac guage from auto part store  to see where your pressure at
Pride - is what drive a man to do his very best even when no one is looking ..
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
  • Member since Feb '08
« Reply #4 on: Jul 10, 2008, 03:22:21 PM »
. Your freon level could be low or high also you could have a expansion valve freezing up on you
4-lo [OP]
  • Male Posts: 752
« Reply #5 on: Jul 10, 2008, 04:52:25 PM »
a/c clutch is engaged when it blow hot air...but what i notice is that when the a/c work the rpm drop and when it starts to blow hot air the rpm jumps.
4-lo [OP]
  • Male Posts: 752
« Reply #6 on: Jul 10, 2008, 04:54:23 PM »
ac guage shows norm...and elect fan still works...you can hear it when it kicks on and off..
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
« Reply #7 on: Jul 11, 2008, 08:51:03 AM »
What are the gauge readings on it when its blowing cold and then when starts blowing warm again.
4-lo [OP]
  • Male Posts: 752
« Reply #8 on: Jul 11, 2008, 04:40:04 PM »
if i remember correctly it shows norm for both on and off...
Last post Feb 20, 2012, 09:13:41 PM
by fade
Last post Apr 17, 2013, 12:32:00 PM
by Snowtoy
Last post Feb 04, 2015, 06:22:27 PM
by BigMike
Last post Mar 04, 2015, 09:21:57 AM
by dune_it86
Last post Feb 27, 2018, 11:29:21 AM
by AZ Rockit
