cold start injector cross match
Started by 79coyotefrg, July 07, 2008, 01:24:48 PM
i havent confirmed this but knowing how toyota didnt like to change things i would bet it would work
QuoteDescription
First of all, I have tons of these injectors so don't be alarmed when you see the same injector pictured under different Auction titles.Other sellers are selling this as a 22RE Injector when actually its a 3S-FE/5S-FE Camry/Celica Engine cold start injector. It does mount and connect EXACTLY the same as the 22RE injector part number 23260-35010 used from 1983 to 1990. this will NOT fit 1991 and newer 22RE engines. The plug connector is a different style from 1991 to 1995. Of course this will fit ALL 3S-FE engines from 1987 to 1991 found in the Camry and Celica. The early 5S-FE engines used this same injector as well. The part number is 23260-74030 on this injector. If your car is difficult starting when it is cold. this is a good place to begin to get your car fixed. Check my other auction for the cold start sensor that controls this injector. I have both styles listed depending on your year. The sensor also can be the problem. Shipping & Handling is $1.75 within the continental US. $4.00 to AK, HI, PR, Guam, $5.00 to Canada and $8.50 to ALL other countries that can receive shipments the U.S. Please DO NOT ask to end this auction early. Check my other auctions for Toyota Parts. Thanks and good luck.
