1tons and 15s
Started by Rocksnail, July 07, 2008, 11:00:51 AM
Rocksnail
 i did a search but didnt come up with the info i need. i know this has been asked and posted on here before. but i cant seam to find the post. I am running 1 tons under my 82 yota.  and would like to run 15 inch rims. i know i will need to grind the calipers down on thefront. but what will i need to do to the rear end? can i run 15 with drum brakes? do i need to switch to disk? ( wheres a good place to get disk brake conversion parts?) what kind of off set should i be looking for on the rim? any info on this will help out. thank you all. :beer:
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
15's fit on my rear 60 with drum breaks and 3 3/4 inch BS.  you will have to grind a lot out of the front.  or you can get 3/4 ton rotor's and calipers and get some special brackets and then you will only have to grind a little.
Rocksnail
thank you for the info hyena. now to order my rims and get my 39.5 iroks mounted up :beer: :beer:
Pre 77 chevy 3/4 ton calipers, rotors and backing plates.  The backing plates will need to be machined and redrilled to the 60 spindle pattern but thats not a big deal really.
