swap?
Started by bigarms23, July 05, 2008, 07:38:09 PM
bigarms23
i have a 884runner with a v6 and was wondering if a tundra v8 will fit and does anyone know were i could find swap info
i have no idea,  give it a try and post the results
Toymin8r
Quote from: 79coyotefrg on July 05, 2008, 07:54:36 PM
I've seen a Lexus 4.0 v8 done to and 88 and it is demensionally the same size as the Tundra 4.7.  The only difference is the VVti (variable valve timing) makes the valve cover a bit bigger and it makes it a really tight fit under the brake booster.
http://youtube.com/watch?v=UBrc7L9Dtu0
NorCalToy
:flamer: IFS
ninja turtle
hey dan, if you do swap can i be first in line for your 22re?  :gap:
8D3TOY
