SAS for a 2000 Taco is it possible
Started by Dark Chaos, July 26, 2004, 02:34:58 PM
Dark Chaos
I have been seeing allot of newer Tacos with a solid front axel under them on different web sites and it is driving me crazy with no e-mail address to ask questions or even a parts list on what these people are using is this just the power of digital photography?
Does any body have any idea if a SAS swap kit from a 86 to 96 will work on a 2000 Taco 4cyl.
kyle_22r
tacoma axles are wider than mini axles so that's not as great of a swap.  also, the transfer case output is on the driver side so you either need to get marlin's 4 cylinder case adapter or get a driver drop axle
most guys use modified '80-up jeep wagoneer axles or cut down '78-79 ford f150 axles, both dana 44s(ford is hi-pinion).
KYOTA
Marlin
Many for these coversions have been done :thumbs:
For starters, the rack and pinion steering will need to be removed, and a 86-95 ifs p/s box installed.
You will also need to replace the oil pan with a T100 2wd rear pickup model as well.
Marlin
mr4x42u
44 waggy axles seem to be the ticket for the taco..It also has the driver side drop..
josho
hey,
a few websites that offer info:
www.bentup.com  (bought my taco sas kit there)
www.toy4x4.net
www.franketaco.com
www.norcalttora.com  (click on member projects)
all these should get you there.
josho
1996 SAS taco, marlins, lockers, chevies, bla, bla, bla
84runner
So is this something you paln on doing Dark kaos ? Those newer tacomas look so sweet with a solid axle under them and some coils overs or air shocks. There is a black one that runs around town with a can back top  :love:
Dark Chaos
Quote from: 84runner on August 04, 2004, 06:26:24 PM
Quote from: Marlin on July 31, 2004, 09:53:09 PM
Marlin
Quote from: kyle_22r on July 26, 2004, 03:14:56 PM
The thought has been rolling around my head for some time now. I have been doing a lot thinking, researching and planning on this teetering project. I heard the pre 2000 need the 2wd T-100 oil pan and all those goodies. Ford super duty axels would be sweet only problem with that is I would either have it cut down to match the back or put one out back. I would like to keep it as much Toyota as possible. The only things holding it back is time, money and axel selections, New, used or custom? I have been corresponding with Brian from frontrangeoffroadfab.com his company offers a customized axel that runs solid axel Toyota parts, also debating between buying a brand new Dana 44 or going junk yard hunting for one.
iNfErNaL
I would recomend going to a junkyard,looking for a mid to late 80s wagoneer,and pulling it yourself.A buddy of mine picked one up at a junkyard for $100.I believe it might be slightly wider than your rear axle,but not by much,and they are six lugs.I was looking for a dana 60 front not too long ago,and I saw a few wagoneers with complete front axle assemblies,hub to hub.I asked about pricing,and they were all around $135 and $160.In my opinion,that would be your best bet.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
