4.3 swap help
Started by greenjacob, July 03, 2008, 11:40:34 AM
greenjacob
im doing a 4.3 motor swap with a tb350 and adapter wanting to see some pics of other poeples 4.3 swaps.
1986 4runner 93 22re 5.29s locked f/r duals twin sticks 39.5s
Ferg
COToy91
the transfer case shifter is in front of the tranny shifter in a chevy auto tranny setup?
thats weird.
greenjacob
 how much room between the motor and radetior do you have
COToy91
the shifter is a cable shifter and the tcase is forward shift, so the shift base is on the adapter
It is about three inches, i used a dodge three row radiator and it is cooled by two ten inch electric fans hooked to a thermostat.
If you need any specific pictures let me know
greenjacob
did you have to cut your firer wall and can you run a fan off your water pump
COToy91
no i have a body lift which solved that problem and yes i can and did for a while till it blew a blade through my radiator
Cheesemaker
Here's some really good reading on a 4.3 in a 4runner!
greenjacob
i dont have a body lift and dont want one im gona pound the fire wall back or cut it if i have too
AaronB
what did you do for your fuel setup? I was told that those motors run at a low fuel pressure  :dunno:. I was thinking I could get away with my stock fuel tank and run an inline pump   :headscratch:. Also what did you do for the motor mounts? Sorry for all the questions but i am getting ready to do this swap. Thanks
COToy91
I used the weld in motor mounts from AA which rock btw. I disconnected the in tank fuel pump and ran an inline along the frame rail. I believe they are still around 50 psi or so
