which axle setup is the best setup
Started by Bazzi, June 29, 2008, 02:02:54 PM
Bazzi
these quotes are all from this threat... I ditn´t want to steal that one so......
http://board.marlincrawler.com/index.php?topic=47074.0
Quote from: Sluice Box Hero on June 23, 2008, 11:01:32 PM
just get a birf eliminator kit.  it uses a D44 chromo shaft and u joint.  a toyota and D44 shaft are so similar in size that all that is needed to run a D44 shaft in the toy housing is a different pitch on the splining, hell they are even both 30 spl. inners. as for the outter shaft all they do is spline it to 30 for the toy hub instead of 19 for the D44.
problem solved since a chromo D44 shaft ( birf eliminator kit) will be strong enough for you (although a 30spl birf has been tested to be stronger and cheaper) you will never have to do a trail fix again on your toyota axle running D44 shafts inside it.
how much more turn radius do you gain using that  birf eliminator kit. ?
Quote from: Duffil on June 24, 2008, 07:11:25 AM
just remember that a regular u-joint inner will bind before a birfield joint will.
Quote from: rockcrawlintoy on June 24, 2008, 11:53:06 AM
yet the 44 still turns sharper than a toy axle.
uuuu... wich one is it. ???
I thought  that the turn radius on a stock toy was turned down by those adjusting skrewes, so that we don´t brake the birfs. or at least to stop it from binding up.
If my last thought is right, I would have to shave off those stoppers to gain more radius... someone might thing cool that´s a huge gain.... I would have to rebuild my front 3-link because as for now when I hit full turn the tire is close to hitting my rangerover link.
Quote from: Birfailed on June 25, 2008, 01:36:45 PM
I went with 30 spline longs and started blowing up diffs, took 3 sets to convince me to toss the toy axle completely and go with a 60.  Either dump alot of money in the toy axle, or dump alot of money in a 44.
is it possible to shave down that d60 so that the truck would get streat legal with 38-44"  pleace anyone answear me this.
I thought the biggest gain with the d60 hybrid is
1 you can´t shave the d60 down to that with,
2 and ground clerance...
for my half.
I am going for the longfiels, I am also going for the cruiser diffs. wich are 9,5" compared to the d60 wich is 9,75" if I remember correctly. they are drop in just like the 8", and uses the same spline as the 8".
I am thinking if I shave the housing for ground clerance I will be getting the same or simular as an original 8" toy.
the only problem  I have is that the cruiser housings are a litle wider than the hilux.
this is what I am summing up off this threat... pleace set me straight if I am getting this all wrong.
OOPS
Quoteis it possible to shave down that d60 so that the truck would get streat legal with 38-44"  pleace anyone answear me this.
I do not understand what you mean by "Street Legal" You do not have to shave them to make them street legal, they do come off of 3/4-1 ton trucks that are street driven all the time.
slabcs
Relentless
Yoat Goat
Narrowed, means that the tires that don't stick out 2 feet from the fender.
T urning
O ver after
Y ears
O f
T rail
A buse
Bazzi
Quote from: Yoat Goat on July 01, 2008, 10:03:07 PM
exactly.
the threat of the cepecs can´t stick out
