toyota starlet transmission help needed
Started by mookie7971, June 25, 2008, 06:44:50 AM
mookie7971
a friend at work needs a 5 speed tranny for an '81 starlet and he asked me if i can help him figure out if there are any other toyota models that have the same tranny?  he's having trouble finding a starlet to get one out of
thanks
DTB
Well, what series is the starlet tranny?
mookie7971
i'm not sure, all i know at this point is that it is the factory tranny in a '81 starlet and that it's a 5 speed manual....how or where would he find out what series it is?
DTB
ITs probably a k-50.....I have no idea how you would identify it though....its hard to find ANY info on these things
K50
Oil capacity:4.2 lmp pints(2.45L)
Synchromesh on all Forward Gears
Ratios:
First Gear: 3.789:1
Second Gear: 2.220:1
Third Gear: 1.435:1
Fourth Gear: 1.000:1
Fifth Gear: 0.865:1
Reverse gear: 4.316:1
Applications:
Most 5-speed RWD Tercel, Starlets and Corollas with K-series engines.
1986 Corolla with 3A-U and 4A-U engines.
KM20 series LiteAces were fitted with K50 transmissions to 4K and 5K engines as an option, and to the 7K as standard.
mookie7971
from the internet research that i've done, it should be a kp60 series starlet and had a 4K-C 1.3 liter engine in '81-82
DTB
I was reading about c-series trannnys too...its kinda confusing :headscratch:
oddball
Theres a few links at the bottom but I dont know if they are helpful  http://en.wikipedia.org/wiki/Toyota_Starlet
te51levin
It's a K50 (check the aluminum VIN tag in the engine bay to be sure).  Also found in K-series Corollas but good luck finding one of them - most were 2TC or 3TC powered.  Have your friend jump over to www.toyota3tc.com and search around, see if anybody building a Starlet has a K50 they want to get rid of.  Nobody over there uses them.  They swap the engines out for 3TCs and use at least a T50, often a W50 or W58 if they are pushing big power (and some of them are).
