modified park lights
Started by beyondlogic, June 12, 2008, 01:25:31 PM
beyondlogic
Quote from: ORANGE CRUSH on June 03, 2008, 09:15:14 PM
Front corner lights modified for Parking and turn signal 2 stage bulb
how do you do this?
89 3.0 5spd reg cab sht bed pickup, 33x12.5x15 mudrovers, open f & r, custom rear bumper and sliders, IFS Front, 3" BL.
www.bslca.com
http://forum.ih8mud.com/la-bayou-state-land-cruisers/215649-truck-work.html
i think you just pull the single wire  plug out of the light assembly  and replace it with a  2 prong plug :dunno:
brainlessfool
beyondlogic
www.bslca.com
On the taco you have to add a second bulb or change the stock socket to a 2 filament socket and bulb.  But on a earlier truck just cut the white wires (grounds) for the parking and running lights and connect the green with stripe wire from the blinker to the old ground wire connected to the marker socket. Voila park/turn signal light all in one bulb with no hacking of a corner light necessary.  You'll have to swap in a electronic flasher module if you don't like the blinkers being fast, a EL-12 from Napa is a cheap electronic flasher that works great.
beyondlogic
great thanks guys for all the help
www.bslca.com
