22Re
5 speed
37 Super Swamper TSL's with decent tread
5.29's front and rear
front diff is welded
highsteer
ford F-150 springs front and rear
Flow master
Square Front Drive line
Runs Good
Heat works great no AC
Been Rolled
![Smile :)](https://board.marlincrawler.com/Smileys/marlin/smiley.gif)
Whats been done:
new windshield
new alternator
new battery
new clutch. throw out bearing, pilot bearing, fly wheel was machined
new clutch master cyl slave cyl
ring and pinion in the rear with new bearing set,
rebuilt both knuckles, machine shop and everything 16 brand new marlin studs,
top end of motor has been competely cleaned along with injectors being replaced and cleaned,
new valve adjustment screws and adjusting the valves,
replaced power steering pump
replaced all U-joints
main front seal
Custom Panels,
SR5 Front Seats,
nice back seats,
external bus strip,
everything is basically hard wired
mud flaps (CHP)
Few problems
clutch needs better adjusting
EGR reads that its not opening all the way but it is (false check engine light)
input shaft bearing makes a fun sound over 60 mph
ifs steering box could use a few seals
extra parts included, have a few boxes of miscellaneous parts, some beat up half doors that were not finished
all yours
done good amount of work to truck needs someone with money to finish the job
1530 341-7680
1530 519-3041
ask for casey
in chico 4000$$
![](http://img230.imageshack.us/img230/2025/dsc01811dv2.th.jpg)
![](http://img151.imageshack.us/img151/1894/dsc01806lh9.th.jpg)
![](http://img384.imageshack.us/img384/3300/dsc01800df5.th.jpg)
![](http://img384.imageshack.us/img384/6774/dseh5.th.jpg)
