Propain
Started by JohnHalladay, June 03, 2008, 07:28:30 PM
JohnHalladay
Not saying im gonig to im just wondering if i was to convert my 22RE to propane will it still be able to pass DEQ/SMOG in oregon? and i have heard that if you run propane it will not lube your vaulves cause its a dry gas then you valves will take a ::pokinit:: on you. is that true.
JohnHalladay
my bad on the spelling. i was typing too fast.
Homefries
Oregon doesn't regulate vehicle emissions.  Only if your vehicle is smoking badly enough to impair the vision of other drivers.
JohnHalladay
really? i thought they did. when i went through DEQ last year they put a deal over my tail pipe to check emissions
Homefries
Well, I guess from what I just heard that the Portland/ Metro area does do a testing when you renew your registration and your license.  So if your vehicle doesn't pass inspection they impound your vehicle and sell it for parts.   :gap:  Sucks that Oregon has finally started to do this but I guess it is inevitable.  As for the propane setup, I have heard it is all in how you adjust the settings of the injectors and timing, best bet would be to call them and find out.
Rockcrawlintoy
Quote from: Homefries on June 04, 2008, 08:48:04 AM
the rogue valley also does deq testing.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Homefries
Quote from: rockcrawlintoy on June 04, 2008, 06:08:27 PM
WTF??  Is it only in K-falls and/or Jackson county?  I have never had to do this with my truck since I have owned it and I live in GP.
Pat Just
Oregon has a law any vehicle over 20 years old does not have to do smog testing. i had to do it with my blazer in Medford. the DMV required the pass to renew my tags and change over the title.
