i am a former professional welder-there are myths and sayings but heres the facts from the oregon structural enineers union-in my wordsyes there are fumes-weld in a well vented, or fan blown areayou can weld structurally if you remove the galvinized coating at least 1/4 inch from the weld surfaceif this is done on both surfaces-strength loss is minimal if present at alland in my opinion, if you have to do it, so be it-but non galvanized is easieryes it will hold paint if prepped normally-although it will always look like ass IMHOi used to weld galvy plate to galvy pipe for pile driving type situations, then houses sat on em-so yes it is plent strong- but if you try to weld without removing the coating- it will leave voids, pockets of gas and air, and not pennetrate well, resulting in a poor quality weldhope that helps
the long term effects are...you end up looking like CrawlerDan but seriously, i puked black foam a few times
activated charcoal is much better than milk
wouldn't zinc make the metal rust faster? i read somewhere on here about putting a zinc block on the underside of the truck to attract some type of chemical so the rust eats it away before anything else. said it was a technique used on boats.
WELDING ON GALVANIZED METALSOne of the most significant health hazards in the welding process is the generation of fumes and gasses. Do you weld on galvanized metals? Zinc is the coating used on galvanized metals, and when you heat the metal, it produces vaporized metal droplets which are called fumes. This is the smoky haze which consists of fine particles of metals or silicates. When you breathe these fumes, they may work deeply into your lungs.The typical effect of breathing zinc fumes is metal fume fever. One or two hours or more after welding-without proper personal protection-you may experience severe thirst, pain in the legs, shivering, congestion in the head, dryness and tickling of the throat, and a cough. In very bad cases, you may feel severe shivering, a high fever, buzzing in the ears, nausea, vomiting, and even hallucinations and convulsions. Your symptoms will usually last 24 hours.Some of you may weld for a period of time and find some of the symptoms appeared, then went away. You may actually have built up an immunity that hides the full effects. If you take a break from welding over the weekend or over a holiday, the symptoms will often come back again the next time you weld on galvanized metal. Because of this behavior, metal fume fever is sometimes known as "Monday morning sickness."Protect yourself, if you weld on galvanized metals, by following these precautions: In all operations where metal fumes are present, you should work in a well ventilated area. The best way to protect yourself against metal fumes is to use local exhaust ventilation at the source of the smoke. Do not re-circulate the air in the shop. If good local ventilation is not possible you should wear an approved respirator, which will fit underneath your welding helmet, to protect yourself from fumes. This respirator collects the fume particles and keeps them from entering your lungs. (A paper dust mask is not adequate). If you find white dust inside your welding shield, you are not properly protecting yourself from the fumes. After you have finished welding, wash your hands and face thoroughly with soap and water. Do not eat, drink, or smoke in areas contaminated by welding fumes. If you think you are experiencing symptoms of metal fume fever, report it to your supervisor. Physicians familiar with this illness say that the best treatment is to drink plenty of water and go to bed and rest. Finally, did you know that you can "contaminate" your family by bringing home zinc particles on your clothing? Protect both yourself and your family-weld safely.
I would probably do a little more than that (maybe 1/2 inch or more) ....just to be safe
Started by BMFN_TOY Parts For Sale
Started by jays68yak Parts Wanted
Started by BLACKDOG Parts For Sale
Started by toyodaaddict Newbie Questions
Started by NorCalToy Bumpers, Cages, and Tube Benders
