How do go from my toyota hard lines to Monte Carlo calipers (rear disk)
Started by CGuava, July 16, 2004, 10:01:36 AM
CGuava
Okay, i got the FJ80 Master, Rotors, Prop Valve, Calipers pads...everything is on there, just need to figure out how to go from toyota lines to the GM Calipers. Howd you guys do it? Could i just buy the fitting and reflare my toyota lines with the new fitting on there?
Thanks in advance,
Christian
Does the it need to be rubber soft lines into the caliper?  Any help is greatly appreciated.  Thanks!
88 Runner, SAS, Duals, Locked, MT/R's, Bilsteins, Toobed.  The usual stuff.
Yep just put yota nuts on 1/4" steel line and run them out to the calipers.  Monte calipers are "floating" calipers so you do need to use rubber lines.  The stock ones from the Monte should work perfect.
