Official MCR7 Registration Thread --- Sept. 12-14, 2008
Started by BigMike, May 20, 2008, 01:06:56 PM
46&2
#300
Quote from: Monster Yota on August 03, 2008, 09:52:51 PM
Would you mind sharing what is on the Safety Check list, that way I know what all I have to fix....
Sure:
Quote from: MCR7 2008 "Safety Check-list"
  • Roll bar, Full cage, or factory hard top
  • Functional parking brake or Micro-Lock system to include a parked position. Each vehicle must demonstrate that its braking system works.
  • Operable brake lights
  • Tow strap, rope, chain, or cable. (Recommended rated at 2 times the vehicle weight.)
  • First aid kit
  • Jack capable of lifting the vehicle and a tool capable of removing lug nuts (dont forget wheel locks)
  • Spare tire equal to or within 3 inches of existing tires on the vehicle (No temporary spares.) Spare tire must have 3/32" minimum tread.
  • Fire extinguisher with gauge indicating good/full, appropriately stored.
  • Seat belts for all passengers.
  • A working CB Radio.
  • Antennas must not exceed 4'6" (except when longer antennas/whips are required by certain OHV areas)
  • Adequate attachment points front and rear. (tow hooks, receiver, etc. tow balls are generally not recommended)
  • Battery hold downs (No bungie cords).
  • Spill kit for any type of oil cleanup.
  • Current vehicle registration and proof of insurance.
kiyul4130
5 1/2 weeks to get my butt in gear and get the truck finished. i hope i can make it in my rig!
-kiyul-
ECV 7-11
KYOTA FOREVER
toyotanner
BLACKDOG
Quote from: toyotanner on August 04, 2008, 10:19:46 AM
we have to have everything on that list?
you should have most of it anyway, on regular wheeling trips.  These are all very good things to have, for safety reasons.  :dunno:  The CB is really the only thing I don't see as a necessary thing, as long as someone in your group has one, and MABYE the spare, depending on what kind of tires you have.
              -Ronald Reagan
We adhere to the safety guidelines from CAL4WD and TLCA which is where that safety checklist is derived from.
However, we do not have any "official organized runs", so we are not able to police each vehicle.
Having said that, we provide the CAL4WD and TLCA safety check list as a recommended list of safety and trail preparedness that we STRONGLY URGE ALL ATTENDING OUR EVENT TO FOLLOW AND ABIDE BY.
I, for example, in the past have abided to every rule except for a spare tire (I only have our Ultimate tire repair kit). But this year I will have a spare tire thus fully complying to the safety check list.
I advise everyone to fully comply with the CAL4WD and TLCA check list for yours and the safety of others.
Thank you
46&2
Cool, that is what I was thinking. Thanks BigMike for clarifying. :biggthumpup:
poop-zuki
 so were not required to have a exo or roll cage?  because all i have is the factory samurai roll bar in the back   :-\
Monster Yota
Is that CB antenna thing really that big of a deal, I have a 5' antenna, lol a couple inches different, will that be a problem, and I do not have a spare, but am running 38.5 SX's  :qtip: (actually I could borrow a 35" tire for a spare but that would be 3.5 inches diff instead of 3" is this ok) What does a spill kit include? Rags and degreaser?  For my front tow point I have a nice spot where my tow strap goes through the spring hanger, this is what I have always used. Do i actually need a "tow hook" or "shackle" ?
Thanks,,,  :beer:
MARLIN 4 PRESIDENT!
RE CB antenna: I believe that restriction came about from back in the days of whip antennas. I used to hear about many injuries caused to bystanders from long whip antennas. For this very reason, hopefully less people use them today compared to the past.
RE Samurai roll bar: The factory roll bar should be right behind the B-pillar, correct? We just recommend everyone to be prepared and be safe. Ask yourself what would happen if your vehicle was involved in a slow roll over? If your seat head rest will hit the ground before your roll bar, then I would be concerned for your safety.
DTB
Quote from: Monster Yota on August 04, 2008, 12:24:23 PM
my homemade spill kit consists of oil-dri, rubber gloves, a couple trash bags and a small spade
BLACKDOG
Thanks,,,  :beer:
Like mike said, its to keep people from using the whip antennas.  Wheeling in a tree filled environment with a whip antenna is just asking for trouble.
Personally with SXs, I wouldn't worry about a spare, thats what I meant about the type of tire, seeing as how you can run 60 mph hour on the freeway with 0 psi in them :smack:
My spill kit is a bucket, with som paper towels, rags, degreaser, and I keep a shovel in my truck.
I think when they say tow hook or shackle, they simply mean a towpoint, so a recovery can be made :thumbs:
keep in mind this is my interpretation, and the one I've used on this event before.
Basically they just want you to come prepared!
Hey Big Mike!!  Any updates on the list yet?  I sent my registration in!! :down:
              -Ronald Reagan
CLC
Quote from: mickey_rubicon on July 30, 2008, 12:39:18 PM
im worried I don't see my name on the list - mailed in registration over couple weeks ago, any sign of miklos and kevin in the mail call?
As of today, I haven't seen a registration for miklos and kevin. What address did you send it to?
CLC
#313
Quote from: BLACKDOGHey Big Mike!!  Any updates on the list yet?  I sent my registration in!! :down:
Yes, I received your registration in the mail on Friday. Your info went out today. Big Mike will get the new info up soon. Looking forward to seeing you there at the Round-up.
Mrs. Crawler :turtle3:
BLACKDOG
#314
Quote from: CLC on August 04, 2008, 03:33:53 PM
:woohoo:  :spin:  :woohoo:
              -Ronald Reagan
Waterman
Just checked the list, I'm not on it....reg was mailed early last week so was checking to make sure you got it.  Also, Looks like Eric (Bad CoCo) won't be able to ride shotgun as planned so we are now minus one paramedic.......Bob
CLC
Quote from: Waterman on August 05, 2008, 12:38:24 AM
Received it last Friday and sent out your receipt yesterday. Sorry we'll be down one paramedic. Looking forward to seeing you. :thumbs:
Christine :turtle3:
UKMyers
Sweet.. #93 on the list. I'm still looking for a group that is going in via the Tahoe side on SAT morning. Also has anybody had any issues with leaving their tow rig and and trailer at the staging area there? I just had some stuff stolen from me and I'm a bit paranoid now. My rig is fully street legal but on runs like the Con it's nice to have the option to trailer it home in case I break it bad.
Monster Yota
So is everyone going to try to be at the Springs on Fri, or are we heading up on Fri, and be at the springs at Fri night/ Sat?  :confused:  Also I am finishing up my rig, :qtip: (untill i get more money) who all is going up on the loon side that could have another rig caravan in there group? A few guys I was planning on coming up with cant make it...  :outtahere:
Thanks,,  :beerchug:
MARLIN 4 PRESIDENT!
*FFC*
My plans are to be there by saturday morning.  That means wheelin in Friday morning and if I have to, wheelin through the night friday night.  It's always taken us forever to get there when we go in Loon....
IF I have my rig..... :outtahere:
blackdiamond
I'm planning to arrive at the Loon side on Friday in before noon.  I'll be making the long leg of the trip (WA to CA) on Thursday and plan to be within a couple of hours of the trail for Friday morning.
snowshoebrue
i plan on going in through loon on friday morning
poop-zuki
has anyone els had problems with things getting stolen from there trailer and trailer rigs at the parking area? :-\
CLC
Quote from: poop-zuki on August 06, 2008, 01:37:23 PM
Marlin & I have parked our trailer & rig there at Loon many a time without having anything bothered. We just make sure that the truck & camper shell are locked up. Other than that, we have never had any problems and we have parked there at least once a year for the past 20 years or so.
CLC
Quote from: Monster Yota on August 05, 2008, 03:54:55 PM
Thanks,,  :beerchug:
We'll be up there sometime Thursday afternoon or evening. We generally like to get an early start on Friday morning and go straight to the Springs. We usually have a good group running with us.
*FFC*
Quote from: CLC on August 06, 2008, 03:01:25 PM
:hyper: If we get there in time we might be able to trail behind ya'll :hyper:
poop-zuki
OK thats good! i was just wondering cuz its my first time attending the round up :D
