Author Topic: 63" Chevy Rear Springs.  (Read 6951 times)
Dixieland87Toyo
  • Male Posts: 29
  • Member since Jul '07
« on: May 13, 2008, 04:02:56 PM »
What mods would I have to perform so that I can put the 63" Chevy 3/4 Rear springs under my 87 Standard Cab Toyo? Sorry if its a dumb newb ? but I gotta ask it . LOL Thanks JD. Ohhh and if there is mods, if anybody had pictures for a detailed look at whats goin on thanks
focushere
  • Member since Oct '07
Re: 63" Chevy Rear Springs.
« Reply #1 on: May 13, 2008, 08:52:20 PM »
you could search too that always work type it in google and see what happens
http://board.marlincrawler.com/index.php?topic=19277.0
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=20665
http://www.google.com/search?hl=en&q=63%22+chevy+Faq+toyota
When i  was new to the internet i was afraid to search too
 thats why i have under 30 post becasue everything can be found by looking around
if there is a question it has usually been answered before...
weirdtimes_7
  • Male Posts: 1,032
  • Member since Nov '06
« Reply #2 on: May 15, 2008, 05:26:11 PM »
As far as io have heard, there isn't a lot of changing or modifying your rear suspension, they should set eyelet to eyelet. You'll get great flex out of em, but make sure you get the 63's out of the same truck or they'll have a different "droop" to em
military_stang
:respect:
TxFireman
  • Male Posts: 44
  • Member since Apr '08
« Reply #3 on: May 15, 2008, 09:53:09 PM »
What do you mean by 3/4 rear? 3/4 ton? I'd just use the 63's out of a 1/2 ton if that's the case. They should flex better then the heavier rate of the 3/4 tons, plus the 1/2 tons are probably easier to find at a salvage yeard or anywhere else for that matter. The 63's in the back of my 97 K1500 flex like mad (they're only limited by the shocks which are a longer stroke than the normal 4" springs). I have a 4" lift on it, and my 48" hi-lift cannot get the weight off the rear tire at full heigth. In order to change a rear tire I have to chain the axle to the frame to limit the travel. The front IFS is another story.. lol.
82 Toyota SR5 SB 4WD stock w/ 30's
97 Chevy K1500 4" w/ 33's
89 Chevy K5 (Trail project, w/ a huge parts pile)
06 Hummer H3 stock w/ 33's
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #4 on: May 15, 2008, 11:01:40 PM »
:werd:
              -Ronald Reagan
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #5 on: May 15, 2008, 11:04:18 PM »
military_stang
:respect:
you still need to relocate your spring hangers and shackle mounts to run them with the axle in the oe location....
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #6 on: May 16, 2008, 06:20:08 AM »
I used the 3/4 ton springs and took out like 5 leafs to turn the pack in to a 3 leaf + overload pack.
TxFireman
  • Male Posts: 44
« Reply #7 on: May 16, 2008, 08:23:28 AM »
That'll work too.  :yupyup:
sabenson82
  • Male Posts: 70
  • Member since Mar '08
« Reply #8 on: May 16, 2008, 10:55:25 AM »
Not many mods needed.... spring hangers, shackle mounts, and with the amount of travel you will get i would do a shock tower and run some longer shocks. You may also want to run LONG steel-braided brake line(s).  Ill see if i can come up with some pics for ya
Build it, Break it, Build it again...STRONGER
weirdtimes_7
  • Male Posts: 1,032
« Reply #9 on: May 16, 2008, 03:54:48 PM »
AH.... mmmm, i see.. now i know what i have been doing wrong, :haha: j/k
military_stang
:respect:
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
« Reply #10 on: May 16, 2008, 04:04:24 PM »
Even though the pirate 63 swap FAQ has everything you need to know, here is where I relocated the rear hanger for the 63s. I wanted to use my stock shackle mount and utilize a double shackle set up using a stock 4wd chevy shackle and a 6" toyota shackle.
This is where I mounted the chevy spring hanger (per the Pirate FAQ)
Leaves the centerpin in the perfect spot
Double shackles drooped out
Ride height (full weight on the springs)
And finally where I relocated the shock mounts (upper and lower)
speedemon
  • Turtle Points: 13
  • Male Posts: 267
  • Member since Nov '05
  • When's winter?
« Reply #11 on: Oct 10, 2008, 01:03:06 PM »
Sorry to dig up an old thread but do your double shackles ever go the opposite direction? im guessing the shape dosent let them do that.  I like that setup.  I'm suprised i havent seen that before.  I used to have buggy leafs but when i went to 36" tires i had to take them off cause the plates holding them on were gouging my tires.
2002 Tacoma sold
'84 pickup SOLD!!
'83 pickup will rise again
'86 sas runner DD
'89 runner project (for sale)
F-Toy build in progress
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #12 on: Oct 12, 2008, 10:21:56 PM »
Never had an inverted shackle in 3 some years running this set up (rubicon and fordyce tested), using the stock chevy 4wd shackle helps I think. Even at full droop it still keeps an angle on the shackle/shackle connection point where it can't bend back the other way. I have hung my rear tires feet off the ground and never had them invert.
joey0712
  • Male Posts: 1,459
« Reply #13 on: Oct 12, 2008, 10:27:47 PM »
I love your shackle set up... could u post some flexed pics or anyone else with pics.
Thanks Joey
91 Toyota High pinions f&r.
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • California livin'
« Reply #14 on: Oct 12, 2008, 10:38:50 PM »
This is the best pic I could find. It was mostly the chevys and the 6" shackle doing the work, The chevy 4x4 shackle had not even left the frame yet.
dune_it86
  • Male Posts: 323
  • Toyfanatic
« Reply #15 on: Oct 14, 2008, 02:40:52 PM »
so if i run a marlin front spring mount, and 5" springs how do i get the same amount or lift out of my 63" springs, do i just make taller frame mounts on the front of the 63?
COToy91
  • Turtle Points: -21
  • Male Posts: 1,241
  • Rollin on 37's
« Reply #16 on: Oct 14, 2008, 06:00:39 PM »
No, that will create a massive rock anchor. If thats an issue you run either a longer shackle or some put small 1" lift blocks on.
LOL @ IFS
  • Male Posts: 292
  • Not so common common sense.
« Reply #17 on: Oct 16, 2008, 11:36:11 AM »
I disagree.  I had them in my Taco, and they didn't flex any better than stock.  They rode better and were a cheap alternative to a new set of leafs, but I wouldn't recommend them to anyone that has more than $45 to spend on a set of leafs.
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • i think i'm cool
« Reply #18 on: Oct 16, 2008, 12:08:06 PM »
Luv the 63's   :yesnod:
Last post Dec 20, 2004, 11:04:38 PM
by awhotrods
Last post Apr 20, 2005, 01:18:09 PM
by PinkToyota
Last post Apr 13, 2005, 07:37:39 AM
by TRDISMO
Last post Jul 16, 2009, 04:47:14 PM
by brockbuilt85
Last post Nov 29, 2009, 05:16:37 PM
by solidmaui78
