Author Topic: Header leak  (Read 2205 times)
YouBet
  • Male Posts: 182
  • Member since Nov '07
  • 85'n it!
Header leak
« on: May 08, 2008, 11:32:40 AM »
I just put a Pacesetter header on my '85 pu 22r and I have to re-tighten almost ever nut at least once a week. Would locktite be a bad idea?
« Last Edit: May 15, 2008, 08:50:17 AM by YouBet »
'85 p/u, 38 15.5 TSL radials, Duals, Welded IFS Rear, Chevy 63's rear, 2.5" wranglers up front, MP's front bumper & sliders, Exo,Winch, 5pt harness', Hy steer power steering convers.,Bed cage, Sweet custom rattle can paint job.
tech201
  • Male Posts: 141
  • Member since Jan '08
  • this is who we are this is what we do.
Re: Header leak
« Reply #1 on: May 08, 2008, 07:23:30 PM »
I think locktite would be a bad idea on a exhaust system exhaust bolts and studs already have trouble with seizing and breaking. are you using an aftermarket gasket or factory. and are they studs or bolts if their studs you could use machine lock nuts or double nut them I wouldnt use nylocks the nylon mite melt
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Header leak
« Reply #2 on: May 08, 2008, 08:43:57 PM »
I do not know if the 22r is the same as the 3.0 but the head pipe on my 3.0 kept coming loose until I put the clamp and bracket back on down by the bellhousing.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
Re: Header leak
« Reply #3 on: May 09, 2008, 07:38:55 AM »
How thick is the header flange where it bolts to the head? I know if the flange is not thick enough, it can warp and cause the nuts to come loose all the time. My LCE header has a 1/2 inch flange, and it has never loosened bolts. But my friends 350 has some headers with I think is a 3/8 flange, and it comes loose all the time. Not the best example, I know, but it does show that there is a difference.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Header leak
« Reply #4 on: May 09, 2008, 08:26:26 AM »
I just put a Pacesetter header on my '85 pu 22r and I have to re-tighten almost ever bolt at least once a week. Would locktite be a bad idea?
are the studs  coming out of the head  or  are the nuts  loosening ??
Pacesetters  are known  to suck
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
Re: Header leak
« Reply #5 on: May 09, 2008, 08:54:06 PM »
Also, are the nuts loosening, or are the threads IN the head stripping out? I have seen instances of that, too. Not quite stripped, but with vibration/heat, jumping threads.
SAVE TELLICO post 491
YouBet [OP]
  • Male Posts: 182
  • 85'n it!
Re: Header leak
« Reply #6 on: May 12, 2008, 05:43:38 PM »
They are studs coming out of the head. Im using an after market gasket, the one that came with it was a joke. The flange is pretty thin maybe 3/8" I talked to a buddy of mine and he said his thorley did the same thing. I'll try some lockwashers and see if that helps.
Thanks
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Header leak
« Reply #7 on: May 12, 2008, 05:54:13 PM »
Thanks
Head maybe stripped........
I ended up installing threaded inserts on all my exhaust studs.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
Re: Header leak
« Reply #8 on: May 12, 2008, 06:20:27 PM »
i dont know if this had been covered-but toyota used brass or brass covered nuts on manifolds so that expansion and contraction could be kept to a min.
use factory hardware with locknuts and it should be fine, i did on my first 22r and went 5 years without a bolt coming loose, and on my 2nd now ive gone about 4 years
YouBet [OP]
  • Male Posts: 182
  • 85'n it!
Re: Header leak
« Reply #9 on: May 13, 2008, 10:17:42 AM »
Ok, thanks for everyones help I'll let you know when I get her dialed in.
Last post Oct 11, 2004, 05:18:22 PM
by Mike D
Last post Mar 10, 2005, 09:12:22 PM
by jackedyotaaaa
Last post Jan 24, 2007, 11:32:51 PM
by Ben Dover
Last post Nov 09, 2007, 06:03:13 AM
by OOPS
Last post Jan 13, 2008, 07:17:08 PM
by Thomas P
