Author Topic: drive shaft help  (Read 3656 times)
pyrosnow911
  • Male Posts: 418
  • Member since Mar '07
drive shaft help
« on: May 06, 2008, 06:01:23 PM »
hi im putting the marlin 4" lift (5" springs in rear) and dual cases under my 4runner. i was gonna buy a front drive shaft from someone that was for a dual case set up and h said it has 6" of slip, but im also going to be running a hp elocker up front so would that add some extra slip to it and if so would that be enough to keep my shaft from disconnecting when im flexin?
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: drive shaft help
« Reply #1 on: May 06, 2008, 07:03:44 PM »
build a square one
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: May 06, 2008, 07:26:16 PM »
in a word  yes
pyrosnow911 [OP]
  • Male Posts: 418
« Reply #3 on: May 06, 2008, 08:08:54 PM »
build a square one
but then im stuck going under 25 when im trying to 4h to go to the snow.
OOPS
  • Online The 2.5K Group
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: May 06, 2008, 08:10:51 PM »
6" is pretty short on slip. I know it would come apart on my rig.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #5 on: May 06, 2008, 08:41:26 PM »
ive ran my square front up to 50 with very little vibration
pyrosnow911 [OP]
  • Male Posts: 418
« Reply #6 on: May 06, 2008, 08:48:57 PM »
really? you just made sure its perfectly centered?
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #7 on: May 06, 2008, 10:18:12 PM »
yep, i double checked all my measurments, and it turned out pretty good, im rocking a square one on my crawler too, but the slip is still toyota, the shaft is just square
91 super yoda
  • Turtle Points: -56
  • Male Posts: 400
  • Member since Sep '04
  • Axe' em Jacks
    • Old Town Customs
« Reply #8 on: May 06, 2008, 11:16:04 PM »
if you wanna do some 4 hi stuff I would actually steer away from a square shaft. even if you check and double check measurements it is still next to impossible to balance. this is going to turn into more of a debate really but if you already have the shaft, then cut out the tube thats on it and re-weld a piece that is longer so it will fit. you will be much happier with a round over a square
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #9 on: May 07, 2008, 01:51:05 AM »
I've got 5" all pro's and I've pulled apart my front driveshaft with 10" of spline so I would say yes you need more slip.  I had it lengthened 2" and haven't had a problem since but 6" is cutting it a little close.  Square driveshafts belong in the Fontucky fab section, I would't recommend it.  Even if your local driveline shop doesn't work with long travel stuff it isn't that hard to go to a farm supply store and get farm implement spline and shaft and just have the shop weld it together and balance it for you.
Quote
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #10 on: May 07, 2008, 05:32:20 AM »
Thats a pretty strong statement. I'd put my square shaft against a round one, implement, or profeshionally built, any time strength wise! Square round or triangle , it really is a matter of opinion.
Hey Steve  you gonna follow my lines at Flatnasty in a couple weeks?  :gap:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #11 on: May 07, 2008, 05:35:46 AM »
Yea, it wont be hard to follow! We can hear your square shaft clanking from the other side of the park  :talkingn:
jk (kinda)
 :smooch:
Quote
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
« Reply #12 on: May 07, 2008, 05:49:41 AM »
jk (kinda)
 :smooch:
:rofl:
We'll see Gittinit.  If I don't it ain't cus I'm worried about a driveshaft breakin.  Maybe if you would bend up a jungle gym on my truck like you got I would.  I just don't like square shafts cus I don't care what anybody says, they can't be balanced.  I hear it from everybody blah blah blah.  I can do 50mph and no vibration blah blah blah.  I just don't believe it.  I never said they are inferior strengthwise.
Quote
« Reply #13 on: May 07, 2008, 05:59:41 AM »
maybe some sch 80  tube  :think:
« Reply #14 on: May 07, 2008, 06:01:42 AM »
if Gittinit or WillyMammoth  builds  it  it will run true :yesnod:
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
« Reply #15 on: May 07, 2008, 06:03:57 AM »
jk (kinda)
 :smooch:
I will find out next week if that was the square tube or the lockright. Wanna place your bets?
« Last Edit: May 07, 2008, 06:56:06 PM by Gittinit »
my favorite places:
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
« Reply #16 on: May 07, 2008, 06:11:13 AM »
OK guys.  We're hijacking this guys thread.  This discussion is better around a campfire after lots of  :beer: anyway.
Sorry pyrosnow911.  You can have your thread back now.
Quote
pyrosnow911 [OP]
  • Male Posts: 418
« Reply #17 on: May 07, 2008, 07:15:52 AM »
ha its all fine and good! if i never figure out what will work at least i got some entertainment  :rofl2:
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
« Reply #18 on: May 08, 2008, 10:05:11 PM »
Check out this thread.  This is what can happen with a square driveshaft.
http://board.marlincrawler.com/index.php?topic=45495.0
Quote
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • Member since Dec '03
  • RIP Kyle
    • Buy me a soda
« Reply #19 on: May 09, 2008, 07:57:44 AM »
dont make it sound like its the end of the world. i know many people have have run square d lines with no issues. it is a killer way to make a longslip shaft without droppin 300 bucks
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #20 on: May 09, 2008, 08:02:42 AM »
I didn't know a long travel driveline is $300... I was thinking more around half that.
« Reply #21 on: May 09, 2008, 08:58:48 AM »
i made my shafts myself  for the cost  of a new cv kit $30 and a box of 6011 rods
pyrosnow911 [OP]
  • Male Posts: 418
« Reply #22 on: May 14, 2008, 09:41:17 PM »
what are 6011 rods?
OOPS
  • Male Posts: 2,561
« Reply #23 on: May 14, 2008, 10:44:05 PM »
Welding rods.
pyrosnow911 [OP]
  • Male Posts: 418
« Reply #24 on: May 15, 2008, 07:03:10 AM »
do you have a picture of ur shaft?
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #25 on: May 15, 2008, 07:12:46 AM »
sicko   :shake:
Quote
pyrosnow911 [OP]
  • Male Posts: 418
« Reply #26 on: May 15, 2008, 07:19:13 AM »
wow way to twist my words..... im 17 and i dont even do that..... :usa:
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #27 on: May 15, 2008, 07:28:42 AM »
32 going on 17 here!  :talkingn: I was just joking around with ya bud :)
Quote
pyrosnow911 [OP]
  • Male Posts: 418
« Reply #28 on: May 15, 2008, 08:14:59 AM »
haha thats goood :) ha i know thats why im always checking this forum.... its like one huge continuous comedy hahah
Last post Mar 12, 2007, 07:42:05 AM
by MiniSimp
Last post Jun 17, 2010, 04:44:33 PM
by 8D3TOY
Last post May 24, 2011, 12:36:23 PM
by rockin86runner
Last post Aug 30, 2011, 09:54:20 PM
by bigarms23
Last post Mar 20, 2012, 07:17:06 PM
by desrodunes1
