cab removal?
Started by kyle_22r, July 11, 2004, 12:33:33 PM
kyle_22r
well?  anybody ever take their cab off the frame?  when i start getting into my truck for it's buildup, i'd like to pull the cab and bed off of the frame to make everything easier to work on.  i'd plan on taking just about everything out of it...how much work is it?
yotaboy79
getting it ready takes more time than actualy taking it off just save the trouble and gut it disconect wires steering rod ect and get a couple friends to help ya lift it off :beerchug:
Jared
when i removed the cab i had the whole truck stripped.  It was a donor truck so i cut all of the lines, cut all the hoses, unbolted the 6 bolts that held the cab on, removed the whole bumper.  It was a lot of work.  I think it will take about 2 days if you and your friends are goin at it with a couple of 30 packs of cold bud .    :beerchug:    Its nothing to be afraid of.  just lifting it off is the hard part.
kyle_22r
good to know...anybody got a ballpark on what that thing weighs?(it's a 79)
donkeykong
Cant tell you the wight but add the fact that it is a very odd shape and you will need atleast 1 guy at every corner..2 if they are all holding a beer in one hand :beerchug:
moutaintoys
me & my bro started changing my frame on a friday after work and were wheeling sunday by noon
Lets go break somethin "GO NAVY"
KYOTA
Dont know what a Yota cab weighs but I used a backhoe to swap cabs on my 69 GMC :ack:
hawaii500_1999
about a half a day to take it off.
there are 6 mounts going to the fram.  four on the floor board and two up front near the radiator.
take my advise and use air tools.  it will go so much faster.
remove the front fenders, hood, radiator, power steering resivor, unplug all of the wiring off of the motor, (don't worry the plugs won't plug into the wrong ones when assembling them back together.), then coil the wire harness up and tape it to the fire wall, disconnect the brake lines at the frame mounts and the rear line on the pass side at the frame, remove the steering colum, disconnect the fuel lines including the vent from the carb,
one guy in the front and tqwo guys at the rear corners.
i think i got it all,  have fun.
mike
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
kyle_22r
i'm probably not gonna worry too much about wiring, as i'm probably going to redo most of it.  my truck is a mess :smack:  might just strip it all out and go with a painless universal harness
hawaii500_1999
i wouldn't start cutting all the wires.  it's bad practice to burn your bridges.
it doesn't hurt to just unplug the wiring.  shoot it would only take me about ten minutes to do that.
if you want to go with painless then go ahead but why not have a god stock harness in your hand incase if they send the wrong one, or your buddy needs it, or the painless one gets damaged in shipping.  what ever.  it just seems to easy of a thing to do to me to not do it.
