Author Topic: oilpan/hysteer clearance  (Read 2632 times)
canadiancrawler
  • Turtle Points: 69
  • Marlin Rocks!
« on: Jul 10, 2004, 12:27:13 PM »
 I have a little problem here,just put hysteer on my 94 toy with 3.0L and the tierod hits the oilpan.Someone told me i could change oilpans but didn't know to what..
  Been searching and can't find any info,can any body help me?
 Thank-you,Lee
94 xcab V6 sas 9" lift,custom everything,dual tcase,170 to 1 crawl.
  Rocks give me Rocks
burnyota
  • Turtle Points: -36
  • Male Posts: 567
  • Member since Mar '04
    • BURNYOTA
Re: oilpan/hysteer clearance
« Reply #1 on: Jul 10, 2004, 12:32:45 PM »
are you using Lukes kit from 4x4 labs?
canadiancrawler [OP]
  • Turtle Points: 69
  • Marlin Rocks!
« Reply #2 on: Jul 10, 2004, 12:46:58 PM »
  No i am using OTT..
  Rocks give me Rocks
88runner
  • Turtle Points: 756
  • Member since May '03
  • Click me!
« Reply #3 on: Jul 10, 2004, 04:02:30 PM »
you need to cut the oil pan or put a ridiculous amount of lift to clear it.
go to "check my rear's up front" in project research and build up.
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
« Reply #4 on: Jul 10, 2004, 08:53:36 PM »
pull the oil pan off but first mark where it is hitting and look on the inside and see if there will be any clearance problems with hammering it in you will loose oil capacity going that route but hey ya gotta do what ya gotta do
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #5 on: Jul 12, 2004, 02:57:33 PM »
I guess thats why you can move your axle 3 1/3 inches forward on the springs with there hysteer , those hysteer arms must be pretty tall
burnyota
  • Male Posts: 567
    • BURNYOTA
« Reply #6 on: Jul 17, 2004, 10:06:03 AM »
Just checking to see if you have had any luck..i slighlty bent my tie rod and whapped the pan a few times, I have about 2 inches from the pan to rod, and that is at full compression
cgbemis
  • Turtle Points: 560
  • Male Posts: 568
  • I love Marlin Crawler!
« Reply #7 on: Jul 25, 2004, 11:04:58 PM »
3.0 T100 oil pans supposedly have less drop to the front of them, and bolt up to the 3.0 minitruck motor no problem. Also, as for steering contact issues, I found that if you used the older style crossover steering arms, and mounted the lower end of your drag link to the bottom side of the passenger arm (same part of the arm that the draglink normally bolts into, just under instead of on top), you will actually gain a bit more clearance than high steer arms offer.
Last post May 21, 2004, 09:28:11 PM
by *FFC*
Last post Feb 21, 2006, 09:30:06 PM
by Thomas P
Last post Aug 04, 2006, 04:48:46 PM
by olivedrab85
Last post Jan 25, 2007, 10:19:42 PM
by Mnmstoy
Last post Sep 17, 2020, 12:53:33 PM
by 87SR5
