Author Topic: no start or idle  (Read 2139 times)
yota pu/runner
  • Male Posts: 208
  • Member since Apr '08
no start or idle
« on: Apr 22, 2008, 08:36:11 PM »
I ve got an 80 with the 22r block and 20r head but my problem is it wont start with out starting fluid and when it starts it wont idle.  I have to keep it reved to keep it running.  Any help would be awesome.
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
Re: no start or idle
« Reply #1 on: Apr 22, 2008, 09:07:15 PM »
Vacum leak ?
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #2 on: Apr 23, 2008, 12:24:55 AM »
bad carb?, carb's suck, get some pane on it... ya know propane!!
yota pu/runner [OP]
  • Male Posts: 208
« Reply #3 on: Apr 23, 2008, 06:37:38 AM »
thanks. but what would be the best carb i could run for the best price.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #4 on: Apr 23, 2008, 07:05:14 AM »
stock toyota, they work fine for most things if tuned correctly
dt
  • Turtle Points: -107
  • Member since Oct '07
« Reply #5 on: Apr 23, 2008, 10:19:18 AM »
I personly like webers,your carb. might well be rebuildable,wont start most likely, bad accelerator pump,wont idle because of clogged idle circuit,did that carb sit around for a long time,also check your carb solenoids,and like the other guy said ,generally check for vacuum leaks
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #6 on: Apr 23, 2008, 11:06:18 AM »
dude,  with the 20R/22R  hybrid that you have you need  to be running either a 22R carb or a 32/36 weber,   the stock 20R  carb is WAY too small
do you have a fuel pump on the side of the head ??  if  not  its electric in the tank,  and  is obviously not working
pull the fuel line off turn the key  to  on,  see if  any noise in the gas tank
yota pu/runner [OP]
  • Male Posts: 208
« Reply #7 on: Apr 23, 2008, 06:06:59 PM »
where would the accelerator pump be?  im kindof new to most of this.
yota pu/runner [OP]
  • Male Posts: 208
« Reply #8 on: Apr 23, 2008, 06:27:17 PM »
what is the best way to clean the jets on the carb?
« Reply #9 on: Apr 27, 2008, 08:48:08 PM »
are you still running the  stock 20R  carb??  if so  your fuel cut solenoid  is not getting 12 volts
you can run a jumper  wire  to it  and  try  to start it  to find out
you should think about a bigger carb,  like the stock 22R carb =320cfm  the stock 20R carb is only 190cfm
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
« Reply #10 on: Apr 27, 2008, 10:58:03 PM »
Are you getting power to your fuel cutoff solenoid on the carb?
Stock 22 carbs work fine when set up properly...
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
yota pu/runner [OP]
  • Male Posts: 208
« Reply #11 on: Apr 28, 2008, 08:22:55 PM »
sweet deal guys thanks for all the help just rebuilt the carb this weekend and were running good.  ive never worked on carbs before but they dont seem to bad.
Last post Mar 02, 2005, 10:11:00 PM
by AlaskaToy
Last post May 03, 2005, 10:22:03 AM
by 91 super yoda
Last post May 13, 2007, 05:53:00 AM
by 4runner
Last post Jun 01, 2006, 08:19:38 PM
by Plowking
Last post Sep 04, 2009, 02:51:17 PM
by emsvitil
