KC lights opions wanted
Started by Huhwhye, July 09, 2004, 01:33:17 AM
Huhwhye
I want to add some off road lights to my pickup.  I was liking those Slim KC's.  They would fit nicely, 2.75" deep.  They have 2 versions both about the same price.  They have 1 with 130 watt "blue" H3 bulb and the other with normal 100 watt H3 bulb.  I don't care how they look and I know the "blue" one has a fancy finish. :sleeping:  I am more concearned with what will light up the trail better.  I guess since the price is about the same despite the "blue" ones having a fancy finish means they aren't really better per se.
They say the blue light looks whiter and is easier on the eyes.  But is it brighter?  I was once told that the blue part of the light spectrum isn't particularly good for illumination.  Personally I think its just because KC wanted to build lights to go on high end SUVs with real HID lights and wanted them to match.  :stopit:  But I don't care about that, I just want to see where I'm going.
What do ya'll think would be better for the trails?
Thanks in advance
'04 Taco DC 4x4
Just get the standard ones.  After a few years of being exposed to the elements on the front of your rig the glass will either get broken or the reflector will rust.  But there is a big bonus in that happening.  Instead of spending around $25 for KC's "replacement" 165 watt sealed beam bulb, you have the option to go to a local truck stop or tractor supply shop and buy their tractor 150 watt sealed beam bulb.  I have made the mistake of buying KC's 165 watt bulbs once.  All that they are is wagner 150 watt tractor bulbs, I know this because it said wagner 150 watt on the backside of the bulb!  You can usually pick up the tractor bulbs for around $10 generically.
Huhwhye
They both use H3 bulbs so replacement bulbs are the same.  I'm not so much worried about that.  Like you said replacement bulbs are available.  But I am concearned about which of the 2 will give more light on the road.
'04 Taco DC 4x4
The clear ones are put off much better light than the blue ones for what you are wanting to do.  The blue ones have their place though.  They work wonders up in the snow you can see forever then.
TRD_Offrd
ill never buy another set of KC's again  :reg: i had 5 up front on my bumper along time ago and replaced them with a set of 8 inch round IPF's with the cobalt blue bulbs in them and i tell you what those 2 lights alone out did 5 of my KC's hands down.everything on them is water proof and i have had them on and working for 6 yrs now and not one problem  :beer:
Huhwhye
Does IPF make a thin model so I can mount it on a stock bumper.  That's why I like the slim KC's.  And the price is right.  I can get a pair for $100.
'04 Taco DC 4x4
TRD_Offrd
imnot sure,i do belive that they do make a slime line style
84runner
what about PIAA lights ? I know they are pricey but they are good lights and might have the profile you are looking for.
SWAMPER
Yeah I heard PIAA is good....have you looked into Pro-Comp...not sure if they make slim ones....Ive also been loocking for lights...Im thinking of getting 5 of the 8" ProComp lights and mount em on a CARR light bar that I may get :beerchug:
84runner
Ya ProComp makes lights too  :yupyup: I would call 4wheelparts for the Pro Comps cause they own Pro Comp and shuold be able to give you a killer deal , that goes for anything Pro Comp it should be cheaper there than anywhere else  :thumbs:
Skinny_Pedal
hey on the topic of lights. shmucks has hella's on sale right now
Im an OG
