Author Topic: Need Help with Knuckle  (Read 1829 times)
zukjunkie13
  • Male Posts: 378
  • Member since Oct '07
« on: Apr 11, 2008, 09:06:15 PM »
I have an 85 front axle and im rebuilding it and i cant remember which shim goes to which part of the knuckle, top or bottom, i have 3 thick shims. shouldnt there be 4? Sorry for the noob question
Life's journy is NOT about arriving at the grave peacefully in a well-preserved body, but rather to skid in sideways, worn out and beaten, shoutin HOLY Sh** what a ride!!!
crawlinforcrohns.org
sabenson82
  • Male Posts: 70
  • Member since Mar '08
Re: Need Help with Knuckle
« Reply #1 on: Apr 12, 2008, 09:54:51 AM »
I just finished rebuilding my front axle and the kit i had came with 4 thin shims and 4 thick shims... i ended up using one thick and one thin on each, top and bottom. i think the only thing that matters though is how much force it takes to turn the knuckle (12-15lbs. i think), the shims adjust that.
Build it, Break it, Build it again...STRONGER
zukjunkie13 [OP]
  • Male Posts: 378
« Reply #2 on: Apr 12, 2008, 09:56:13 AM »
alrighty thanks for the info
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Apr 12, 2008, 10:40:12 AM »
yes  start  with 1 thick and 1 thin on both top and bottom caps
if you are using Marlins  kit  i can almost garrantee that  will be perfect
if its too loose  remove a thin from the top,  if STILL  too loose  remove the thin from the bottom
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #4 on: Apr 12, 2008, 03:11:54 PM »
Not true. I believe the bottom ones are used to center the knuckle, and the top ones are to set preload on the knuckle. I am pretty sure thats right... maybe not. I think OOPS explained it to me once. That being said, I did one thick and one thin on both the top and bottom, and it all worked out just fine.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #5 on: Apr 13, 2008, 07:48:53 PM »
If you run Marlin's new Super Seals the centering of the knuckle is not as critical as with the stock seals. Pre-load on the bearings is critical, especially if you are running some big, wide meats.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #6 on: Apr 13, 2008, 07:51:02 PM »
I used the super seals :yesnod:
sabenson82
  • Male Posts: 70
« Reply #7 on: Apr 13, 2008, 07:59:05 PM »
yeah, like i said....one thick and one thin on top and bottom
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #8 on: Apr 13, 2008, 09:22:05 PM »
zuk if you need some i have a bunch. get my number from rocky
UA 342
STEAMFITTERS
Last post May 17, 2003, 06:44:51 AM
by Drip_Torch
Last post Dec 09, 2006, 12:47:10 PM
by 42s on u
Last post Apr 24, 2008, 07:46:47 AM
by OAE
Last post Nov 23, 2008, 04:18:18 PM
by *** YELLER ***
Last post Nov 23, 2008, 05:59:58 PM
by *** YELLER ***
