I'll be converting a forward shifting turbo t-case to a top shift to use as a reduction box behind a r150f. I'm either swapping the shift rail/fork, or cutting and welding the existing rail. Basically I wanted to confirm that i'll need a forward shift shifter to bolt to it, since a top shift shifter has a different bolt pattern....
Is this correct?
