Porting works well, from what I 've heard, as most of the power is hidden in the head. If you can swing it,
get yourself an Engine Builder RV head, 261 cam and Thorley headers. I've read good things about this setup and will be installing a fresh 22RE with that stuff into my '81 (along with an FI swap) when I come back from Iraq.The best mod, as it's already been said, is going to be strengthen your noggin... do a lot of searching and the answers will be found.
A 260 grind is considered a RV cam correct?
you tellin me you never wheeled a dolphin? thats a damn shame....
This all sounds pretty good. But I am pretty sure the efi swap wont work on that motor so that oneis out. I have already rebuilt the head so im probably stickin with that. But i will go with a good RV cam, intake man., header, and I had the rotating assembly balanced so the motor should last and be a pretty smooth wrapper. thanks guys. I probably should have just wandered this site rather than starting a discussion i just started on this site.
Started by Ga Crawler Toyota Pickup/4Runner Tech 1979-95
Started by motoracer Toyota Pickup/4Runner Tech 1979-95
Started by Dr.Maxwe001 Toyota Pickup/4Runner Tech 1979-95
Started by TURBO « 1 2 3 4 5 » General 4WD Discussion
Started by ImSlow Toyota Pickup/4Runner Tech 1979-95
