i have a question. i showed u that hood mod. if u still do it, is it gonna be off to the side? because i was looking at 81toy4x truck and noticed the bulge in the middle and was thinking that the vent would not work like that?
Is it just me or is it as tight as it looks from the pulley's to the core support?
Looks like you worked your rear off this weekend
It was a direct bolt in. We put a body lift on the short bed and decided to drop the tank to clean it since the truck hadnt been run in a few years. Well I dropped the tank and it looked just like the tank from my 84 but the top was cut off of the shorty tank. With the body lift and a little massageingof the bottom rear cab seam it bolted right in for a couple gallon extra.
You might not wanna get in too big of a hurry making a custom harness. Remember that youstill need to change the dash, which incolves changing another harness completely.
Is there any room to shave the oil pan in the front? It looks as though it is pretty close to the crank as it sets.
Now I have shackles, moved the axle and have rear springs on front, so no more hitting issues.
29" 1st gen 35" second and third gen.
i see you have been busy while I've been gone.. <snip> i wish I knew what you were up to
so are you done with teh mr2's or just on break?
WT, you went outside at 1:45am to make some measurements on your gas tanks? What did you expect me to do? I said I would go measure them for ya.
Started by Mike D Engine
Started by gturismo Chit Chat Camp
Started by BigMike « 1 2 ... 18 19 » Project Research and Build-Ups
Started by BigMike « 1 2 ... 11 12 » Trail Reports, Events, and Gatherings
Started by BigMike « 1 2 3 » Trail Reports, Events, and Gatherings
