SPEEDCRAWL, april 5th Houston.
Started by bayouhazard, March 24, 2008, 09:46:41 AM
bayouhazard
Compete on the same courses as the pro's!!!!!! Pro built man made courses that challenge even the toughest rigs. There will be three classes: stock to 35", modified to 40's, and texas giants with tires 41" and bigger. You will be given one chance to clear as many gates as possible in a 10 minute time limit. The gates will have 25, 50, or 100 points each. We will turn two trucks loose at a time. There are plenty of obstacles so you can work around the other competitor.
Roll cages or roll bar w/ hard top required, as well as helmets and fire extingiushers. Body armor is recommended and lockers front and rear will be needed to be competitive.
Entry fee is a hundred dollars with a 100% guaranteed payout to the top three in each class. This will be on the same courses as the Werock Grand Nationals competed on last september!!!!!!!
For more info or directions go to springcreekoffroad.com or call Roland at
713 806 9410.
80 pickup swb, 4.3, 700r4, marlin 10 degree doubler, frt+rr 60's w/ 7.17's, full hydro, flat belly'd, 42 irocs, 17" mickey's w/ trailready's.
