Author Topic: elocker wont completely disengage.  (Read 3848 times)
Huhwhye
  • Turtle Points: 24
  • Male Posts: 639
  • Member since Jan '03
  • Huhwhye, esq.
« on: Mar 22, 2008, 07:55:05 AM »
I swapped in this elocker into my 4runner.  You can hear the motor moving but when the locker is off the truck doesn't move. The driveshaft spins and the axles don't. If I hit the locker it works and the shafts/truck moves. So what did I screw up on this thing?  Is there a problem with the locker?
'04 Taco DC 4x4
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re: elocker wont completely disengage.
« Reply #1 on: Mar 22, 2008, 08:13:38 AM »
Sounds like the motor isn't getting enough voltage so it is weak.  Check what voltage its getting, if its getting full 12 volts minimum I'd save money over buying another motor and convert it to cable.
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
« Reply #2 on: Mar 22, 2008, 08:36:34 AM »
Thanks,  I'll check it.  At least if its the motor I can fix that without yanking the 3rd.  I'm in a time crunch to get this done.
Is the Downey cable the only one available?
Do you think there could be an internal problem that would require yanking the 3rd?
'04 Taco DC 4x4
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: Mar 22, 2008, 09:11:10 AM »
Pull the motor and see if you can get it to fully engage/disengage by hand.
If it is the front I have been told the cable will not work, not enough room.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: Mar 22, 2008, 10:01:45 AM »
there's no  place in the elocker  that would be  a "neutral"   if the drive shaft is spinning and the axles (at least 1) arent turning you have stripped teeth off the pinion
« Reply #5 on: Mar 22, 2008, 10:04:38 AM »
if  one axle turns  or  both turn  then you need to pull the motor,  lock it or unlock it by hand,  this is what we call "timing the e locker"
« Reply #6 on: Mar 22, 2008, 10:51:41 AM »
That may be true with the downey cable setup....
Here's mine.
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
« Reply #7 on: Mar 22, 2008, 11:06:45 AM »
thread jack....,sorry. wt, whats up with the shocks on the flip kit? is this something cool i dont even know about?
« Reply #8 on: Mar 22, 2008, 11:36:04 AM »
Nope, I have the tall marlin hoops mounted up on a 2wd frame (same shape as a solid axle frame) so they sit very high in the engine bay.  Unless I had at least 15" bbcs shocks I'd lose downtravel. ;)
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
« Reply #9 on: Mar 22, 2008, 11:42:18 AM »
I going to look at it now.  But the ring and pinion are new and have never been on the road (except from moving it in the driveway).
'04 Taco DC 4x4
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
« Reply #10 on: Mar 22, 2008, 01:37:42 PM »
What does this mean!!!
I pulled the motor and manually engaged the locker.  When it is manually engaged ONLY the Driver's side wheel spins.  When it is manually disengaged nothing is connected and neither wheel spins.
Am I missing spider gears or something?  What is going on?!
'04 Taco DC 4x4
« Reply #11 on: Mar 22, 2008, 01:56:36 PM »
gotta pull it out  something is  NOT RIGHT  :yikes:
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
« Reply #12 on: Mar 22, 2008, 02:12:53 PM »
Just got done yanking the 3rd.  The passenger side splines are not connected to the spider gears.  I can spin the pinion and the splines don't move.  If I move the splines the spider gears don't move.
I don't know anything about these things and have never seen an exploded view.  Are the splines supposed to be in 2 pieces?  Like an inner (connected to the spider gears) and an outer that just floats?
Something must be missing in there or broken?  Is it possible this would not have been caught during R&P setup?
« Last Edit: Mar 22, 2008, 02:41:22 PM by Huhwhye »
'04 Taco DC 4x4
« Reply #13 on: Mar 22, 2008, 06:47:03 PM »
we need pics
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
« Reply #14 on: Mar 22, 2008, 08:22:54 PM »
The yellow arrow points to the outer splines that spin freely.  The red arrow points to the inner splines that appear to be connected to the side gears and spider gears.  I turned the splines so they don't line up so it would show up in the picture better.  Might be hard to see.  Sorry about the grease, I greased the axle shaft splines during the install.
Is there supposed to be a split there?  Seems to be one on both sides of the carrier.
'04 Taco DC 4x4
« Reply #15 on: Mar 22, 2008, 08:39:46 PM »
:eek:   i think your side gears are busted
i am 99.9% sure my elocker is NOT  like that
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
« Reply #16 on: Mar 22, 2008, 08:58:29 PM »
Dammit!!!  You are correct, I just confirmed this with someone who has an elocker on his workbench.
Can those be replaced or do I have to change the whole carrier?
I need a (edit: another)  :beer:
Anyone have an elocker for sale with a good carrier?
« Last Edit: Mar 22, 2008, 09:26:43 PM by Huhwhye »
'04 Taco DC 4x4
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
« Reply #17 on: Mar 23, 2008, 03:10:38 PM »
Found out Toyota does sell the parts.  Likely special order.  Price is better than buying another used elocker but not by much.  $340 at an online Toyota dealer.  Ouch!
Should I also assume the spider gears and side gear bearings are bad.  Thats $$ too.  i need a  :beer: or 3
« Last Edit: Mar 23, 2008, 04:10:44 PM by Huhwhye »
'04 Taco DC 4x4
Last post Dec 01, 2004, 02:31:36 PM
by BLACKDOG
Last post May 14, 2009, 10:42:54 PM
by Blingn
Last post Jan 30, 2012, 09:29:08 PM
by emsvitil
Last post Sep 15, 2012, 06:07:21 PM
by BoG-ToY
Last post Feb 10, 2016, 10:37:52 PM
by Prismo
