driveshaft?
Started by bigarms23, March 14, 2008, 08:11:31 PM
bigarms23
I have a 19884runnersr5v6 5spd. Last summer i pt a 12bolt(it was free) in the rear and since then i have 2 different shops do a rear driveshaft the shops were southbay driveline and reno driveline&gear and i am still having driveshaft problems in the rear so what company should i try next
BLACKDOG
I had a shop in Sacramento do mine.  did a great job, shortened it, 2 piece to 1 piece, and used thicker tubing.  I'll see if I can remember the name.
              -Ronald Reagan
Rockcrawlintoy
are you runnin a cv? do you have dual cases? you sure its set up correctly.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
bigarms23
yes it is a cv and yeah i have dual cases it setup correctly
BLACKDOG
I'm pretty sure this is the place.  I'm not at home so I can't check the receipt, but I think its right.
702 Houston Street
West Sacramento, CA. 95691
fax-916-371-6477
800-332-2800
              -Ronald Reagan
jrock
Remember what it cost?
BLACKDOG
Quote from: jkief86 on March 14, 2008, 08:27:58 PM
About 200 I think, mabye a little less.  They basically just made a new driveshaft for me.  Replaced the u joints, and used the ends, and the slip joint, but used all new tubing (forgot what size, but a lot bigger dia. and thicker than the stocker)  I'm real happy with it.  They did a good job on it.
              -Ronald Reagan
jrock
Thanks, I think Ill check them out.
bigarms23
thanks for the help guys i will try that place in sac. or a shaft from je reel
SLIVER
My shaft is a Woody!
The one in my 4runner that is.
www.4xshaft.com
))--SLIVER-->
bigarms23
I ll talk to tom wood and see between the 3 i have in mind to see what fits my budget
