L52 to a G52?
Started by bonebuilt, March 13, 2008, 02:49:26 PM
bonebuilt
Besides making a new crossmember bracket will i need to change anything else if i put a g52 in my truck? a.d take out the old L52 its a 83 and i heard i might have to trim the ploor board
John
toyotanner
your going from a top shift t-case to a forward shift so i dont think you should have to even cut out the floor board.
All_Set
drivelines.
xmember
cutting holes into floor.
I believe that's it.
bonebuilt
where at will i need to cut holes at? Are the holes for the shifter location?
John
dude  the G52  is identical to the L52  on the inside,  if you want something  to last  get a L52HD  from Marlin
dont goto all the work of swapping to a  tranny that doesnt fit  thats  no stronger than what you have
where are you located  i have a good used L52
bonebuilt
isnt the g52 longer by about 4 to 5 inches over the l52 im in brookings oregon right on the cali border on the coast
John
Quote from: bonebuilt on March 15, 2008, 07:28:46 PM
probably closer to 6 inches,   but  the  gear set  is  about the same, thats why i said  you shouldnt go to all the trouble of a G52  cause you have to have your driveshafts lengthened  on the front and shortened on the rear,  just like if you were to add dual cases
ouch,  shipping would kill that deal,  i think Lilbuddy still has  a L52  for sale,   check the sale  section  here  and  i bet you can find one close  to you for cheap
I'd swap the g series in even if its the same strength as an L series just for the added length.  When that g series dies just swap a w series in there and be done with it beings all the work on the drivelines is already done.
