How long does your "Oil Light" stay on after you start your engine?
Started by BLUCRUZ, June 30, 2004, 06:27:10 PM
BLUCRUZ
My old Engine only stayed on for about 1-2 seconds. This new engine is taking up to 5-6 seconds for the light to go off. New pump from Engnbldr too,  I think I better change it to be safe. It's got good pressure after the light goes off?
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
brainlessfool
BLUCRUZ
I am using the larger wix filter instead of the smaller diameter one
That should not affect your pressure as all wix filters have a anti-drainback valve to help with matters such as that.
BLUCRUZ
I don't know....15-20lbs at idle & 60lbs at 2500rpm My pressure gauge is hooked up in the port that is behind the right motor mount so it's the last port before the oil goes back into the pump, I guess it just takes a while for the oil to get that far. It was only about a 2 second wait with the smaller filter so I do think that had something to do with it. & no oil cooler
robrocketanski
you said new engine so its rebuilt, i would suspect that. bearing clearance is what makes oil pressure and you almost for sure gained a bit of clearance over the factory.
BLUCRUZ
Quote from: robrocketanski on July 01, 2004, 01:25:06 PM
Very true, I didn't even think about that. I pulled the valve cover and fired it up, it's getting oil right from the get go on the rockers so  I'm not going to worry about it.
