Massive Marlin Crawler parts comparison!!!
Started by superstarai, June 29, 2004, 04:26:51 PM
:o Holy cow!!
Was there something inside the Box that was getting caught between the low speed gear and the counter shafter that caused so much pressure on the counter shaft bearing that it killed it, maybe? Wow :o
tj40ounce
No clue honestly.  Nice carnage regardless  :yikes:
www.lucky13offroad.com
www.realsteel.com
daguy
BigMike you got me sold!  :clap: Do you have one for my Jeep?  :crossed:  :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle:
My Avatar pic. is by Pat Mosley & is of my new
"On Board Spotter"
now in "K" & "Wall",,,Marts every where!
Now Step away from the MOUSE & lets go WHEELING! after you see this video!
   http://media.putfile.com/Big-Brothers--Big-Sisters-4-Wheeling
#63
Quote from: daguy on April 27, 2006, 03:59:14 PM
Yes we do! We have domestic Crawlers available through the ToyBox design Unit.
The following domestic transmissions are supported:
  • SM420
  • SM465
  • TH350
  • TH400
  • 700R4
  • T18
  • NP435
  • NV4500
Also Jeep AX5 and AX15 Marlin Crawlers are available. Please see more info on the ToyBox
bigtoyota
WELL ive noticed marlins machined parts arnt all that great! i bought a long spline and it was bent and couldnt even slide it together and ive bought a dual case adapter and had it in for about 3months and heard a wierd grinding noise... i took it out and saw that a ball bearing was cracked and a chunck was missing from the shaft it was the mc adapter with the bearings pressed in! and a nother hard thing to do is callin the place and talking to some one.... BUT all in all they replaced every thing and i havent had a problem since!
im 18 and a big rig mechanic at Joel olson truckin! cats and cummins.. and dont like workin on my own stuff thats why i choose the best ALLPRO and MARLIN CRAWLER
blackdiamond
#65
Quote from: bigtoyota on October 15, 2006, 06:15:43 PM
:slap:
BigMike - have you taken a look at the Trail Creeper gears from TG to compare the strength?
4RnrRick
Quote from: BigMike on July 02, 2004, 06:22:19 PM
Ok guys, I searched and searched and searched and I've finally found my super old comparison post about our 4.70:1 Gear Set compared to the A/A 5.0:1 set that I posted on the pirates bbs along time ago..
Here is the raw data:
Marlin Crawler 4.70:1 Gear Set:
Input Gear: 20 teeth
Idler Gear: 35 and 16
Low Spd Gear: 43
A/A 5:1 Gear Set:
Idler Gear: 37 and 16
Low Spd Gear: 43
Actual Ratios:
Marlin Crawler 4.70:1 Gear Set: (35/20) x (43/16) = 4.703125:1
A/A 5:1 Gear Set: (37/20) x (43/16) = 4.971875:1
Well here are some physical differences:
Regards,
I see that a competitor is now selling 5.7:1 gears, got any comparision info on those???? Is Marlin planning on selling these?
blackdiamond
Quote from: 4RnrRick on December 21, 2006, 08:41:51 AM
You better provide a link.  I have heard of 4.0:1, 4.7:1, 4.97:1 & 5.0:1 (really 4.97:1 gears), but not 5.7:1.   :dunno:
Trail Gear has a set of 6.5:1 gears for a Samurai, are you looking at a Sami gear set?
From what I know, the 4.70:1 design was chosen because it maximized the available space in the stock t-case housing.  This is why the 4.97:1 gear set is the same diameter and just added two additonal teeth.  It seems that in order to get a 5.7:1 reduction, it would take a bunch more super thin teeth which would be significantly weaker than anything else on the market.
Hottrod81
Quote from: blackdiamond on December 21, 2006, 04:34:48 PM
I believe he is talking about Advance Adapters.
blackdiamond
Hottrod81
I assume if Marlin were to come out with a 5.70:1 you won't hear until it hits the shelves.  I would think that it might be better as far as gear strength goes to just add a 3rd strength.
blackdiamond
#72
http://www.inchwormgear.com/store/product_info.php?cPath=21&products_id=68
Here is the link.
In my opinion, a single 4.70:1 gearset is bordering on too low due to the loss of a middle range of gears that come in handy quite often.  A dual ultimate setup provides a low low combination that it more than adequate.
For comparison:
3.93 x 5.29 x 2.28 x 4.7 = 222.78 or 1.86 mph @ 4,000 rpm with 35 inch tires
3.93 x 5.29 x 2.28 x 5.7 = 270.18 or 1.54 mph @ 4,000 rpm with 35 inch tires
Granted, it is approximately a 20% reduction, but would you really be able to tell the difference in the dual setup?
I still would like to know what the gear design is.
4RnrRick
I'm NOT planning on changing my setup (MC09-R10, 21/23 spline, 2.28 X 4.70). I was just curious on the gear design and a comparision. Since its a lower ratio - I full expect them to be weaker. But it would also be nice to know the overall diameter difference which would tell you approximately how much more material would need to be removed from the T-case reduction housing.
madhunt
have you guys compared the dual adapter from trail gear to the mc07 yet??? and the 4.7 gear sets also?????
HIGH AND TIGHT OFFROAD
megolfer
If you look at the bearing loads marlins is much stronger.  Also the adaptor is cast and is not nearly as strong as aluminum.   They are using a single bearing instead of the double bearing like marlins.  TG is going to say that it is a better adaptor, but like all their products they have failed to show any stats on how their products are stronger.  Truthfully I would be afraid to run anything from them because most of their stuff is made in china.  It is a well known fact that the materials used in china are not nearly as strong as materials used in the US and in other countries.  The 4.7 gearset I would not trust.  Marlins have been out for a long time now with no problems that I am aware of.  Why would you go with anything other than a proven product?  Price means nothing, I would much rather pay more and now that I am getting a product that will hold up and take the abuse.
Hottrod81
But remember, TG does have a lifetime guarantee :shake:  A lot of good that does 20 miles into the Dusy and you have a broken T/C adapter.
madhunt
Quote from: megolfer on December 29, 2006, 06:30:47 PM
but have you looked first hand at one or are you just goin off what you see on the web?
madhunt
since there has been no reply i'm  wondering if big mike or marlin are doing the comparison, or not going to bother with it???
colsoncj
i know this is an older thread, but with all the discussion and talks of adapters, is MC looking into a C6/AOD to yota box adapter for us 302 or other blue oval people?
Additionally, while comparing parts, what differences are we looking at for some "beginner" parts such as the TG IFS elim kit or the Sky SAS kit vs the MC SAS kit?
No offense meant, I'm a MC person especially on proven technologies such as T-case adapters, but I'm wondering about future releases and other products.
:beerchug:
87 4Runner, ProComp IFS lift, Chevy Rears, 4.88 w/ lockers Fr & Rr, plenty of goodies and creature comforts!
#80
Quote from: madhunt on December 29, 2006, 10:17:19 AM
Yes I have but it is still a work-in-progress.
Please read this article: http://www.marlincrawler.com/docs/mc07/index.htm
Regarding 5.7:1 gears, I would LOVE to take measurements of 2.28, 4.00, 4.70, 4.97, & 5.7 gear sets and compute the torque loading capabilities of each gearset. Obviously the higher gear ratios should be have the strongest GEAR TEETH. I have seen gear teeth fail, but remember its the input min diameter that is the true weak link of the gear set, and that is what clearly sets our 4.70 with Total-Spline technology far apart from the rest.
To be honest, I have not seen a 5.7 gear set yet. Once we get one, I would really like to compare all gears together. I remember when Marlin was trying to decide what ratio to make his gear set back in 1997, that Advanced Adapters gear cutter told him that 4.70 is as low as anyone should go, any lower than this the strength really begins to drop very quickly. I would love to verify this mathematically. This would be something I would do in my own spare time like on a Sunday sometime soon hopefully.
Regards,
PAPACASEY
I am wondering how the AA TX2 compares. Bigmike, if you could post any info that would be great.  :beerchug:
Thanks
Casey
5runner
WOW,my money will ONLY go to marlin! Its nice to know of a company that you can trust. thanks marlin. :thumbs: :bowdown:
I will be doing a lot more reviews this fall. Please hang loose until then!
Thanks
Mike
Quote from: BigMike on June 09, 2008, 11:13:18 AM
Thanks
Mike
will do :beerchug:
4runna4me
#87
my money only goes to Marlin too hes a pretty cool cat.
REG535
Quote from: ToxicToy on July 10, 2008, 07:51:10 PM
i believe that allpro also sells the 5.7:1 gearsets
http://allprooffroad.com/index.php?option=content&task=view&id=18
they are made by AA and i think they are hella weak like the 4.0 and 5.0
