Front end......POP!
Started by BLUCRUZ, June 28, 2004, 07:57:05 PM
BLUCRUZ
 :headscratch: I only hear it when I turn the wheel. Definately coming from the right front. Everything is tight :screwy: I can't imagine it being a birfield since I just lightly wheeled it this weekend. I didn't really put it in a position where I even needed the front end pulling hard. Guess I have to take apart  :snare: :mad: :maddest:
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
Is it a bad pop?  does it jurk the whole truck or is it bearly noticable?  Does it do it all the time or just once or twice?
BLUCRUZ
Quote from: Hyena on June 28, 2004, 08:33:57 PM
Barely noticeable, but there, no binding of any kind just a pop when I turn the wheel left or right. I thought it was a spring shifting at first but when I turned the wheel while sitting still it still did it. I then had my wife turn the wheel while I was under the front & it's definately comong from inside the right knuckle.
Is it only when the hubs are engaged? Any difference if the hubs are engaged, 2WD vs 4WD?
If its only occuring when the hubs are engaged, then it could be a cracked birfield. This is very typical on front wheel cars with high mileage because the cv-joints on the cars are always being used. Even the slightest crack or deformity on the joint and it will bind and pop when turning and under torque..
I had the same issue with my 84 both times I killed the lower trunion bearings.  Jack it up and give it the old shake test, my bets on there being a bunch of play caused by wasted bearings.
BLUCRUZ
Quote from: BigMike on June 28, 2004, 11:49:09 PM
Doesn't matter if locked or not same pop when turning the wheel left or right.
BLUCRUZ
Quote from: WHITE_TRASH on June 29, 2004, 02:29:23 AM
bearings & knuckle is tight, no shake
SWAMPER
I dont know if its the same put I have a similar problem except it dosent pop very loud it squeels and pops when I turn the wheel to the far sides not if Im parked only when I turn it and give it a bit of gas...Im guessing I need to lube something (thats what it kinda sounds like) :headshake:
QuoteDoesn't matter if locked or not same pop when turning the wheel left or right.
Well that's good news - its not related to your birfield/third member/driveline/etc - unless your hubs have problems and they dont disengage
How are your motor mounts?
Quote from: LILSWAMPERI dont know if its the same
Your 4Runner is an IFS front suspension while his 85 4Runner is not.........
SWAMPER
Quote
Ok thanks Mike but you dint give me a answer  :headshake:
derek
had some clicking a popping this weekend after some stupid lines wheeling.
pulled right front apart and yup, busted longfield.
derek
84runner
Wow a longfield man  :headshake: how long have you been running these ?
derek
second trip on them, first was a snow run.
was taking some hard stupid lines on the rubicon. :shocking:
the bell was still good, but grenaded the guts.
derek
BLUCRUZ
Not an internal problem at all-worse as far as i'm concerned. Cracked frame at the spring hanger alowing the spring to pivot side to side just enough to have the second leaf slide back & forth & pop- it was moving so slightly I didn't even see it. I put my hand on the spring as we turneds the wheel again today and I felt it move just a mm or 2. I then watched the spring and checked th shackle & hanfger and found the crack in the frame near the spring hanger up front. I be welding tonight! :nerv:
Wow its a good thing that you caught it!  That could have been really ugly.
Prismo
Driving down the road with the front tires in one lane and the rear in another would be exhilarating. :talkingn:
BLUCRUZ
All fixed, Crack has been welded and I torqued the u-bolts just be safe-They were backed off a few lbs.
Guess I'll have to go wheelin on the 4th now :eyebrow:
84runner
Well that sucks but glad you got if fixed  :flamer: what did yo weld it with ?any rienforcement ?
SWAMPER
When my frame was craked I used JB weld and gorrila glue  ( :bull crap:)
