Which is Better?
Started by GA Runner, February 21, 2008, 05:55:31 PM
GA Runner
So i've been hearin a lot of talk about 4-links and leaf springs. which one is better and gives you more flex. i dont plan on doin either right now i was just wonderin
89' 4Runner
brainlessfool
If don right, I'd vote 4-link.
Hammerhead
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
OOPS
If done right, link will give you much more flex, down side more things to break.
crawler925
 i say a 4-link
5" sas with rear 5" coil to leaf conversion , ARB front bumper, 8000 warn winch , front and rear ARB air lockers, 5.29 gears, 36/12.5/15 swamper sx on 15x8 2in back space rockcrawlers, Bilstein 5150 14" Shocks, Bilstein steering stabilizer, cobra CB, onboard air compressor w/7 gallon tank, con-ferr roof rack,
Toymin8r
the 4 link will provide more flex, as long as it is designed and built right.  They are more edxpensive too.  The leaves are much more reliable and have less parts to break.
bigarms23
GA Runner
whats the difference between a 3 link and a 4 link?
89' 4Runner
MiniSimp
Quote from: GA Runner on February 22, 2008, 11:50:42 AM
If you are asking this question, I hope you are not the one building the link suspension....
KDXSR5
toby
A 3 link has 3 links, attachment points from your frame, to your axle. A 4 link has 4. A 4 triangulated 4 link will give you less side to side movement. A 3 link will require a panhard bar. A cross link from your axle to your frame so you don't get side to side movement.
I'm not as good as I once was, but, I'm as good once as I ever was.
2toyotas
twistedtoy92
LOL!!!!! if you dont know what flex is you shouldnt be on this thread!!! you can get some pretty knarly flex outta leaves if you do it right and not too expensive! three link and 4 link flexes the best  but you are loooking at alot more denero and more skills to set it up with the right geometry!!!  im gonna build a trianglulated 4link with coils on the 82 and throw 4 inch marlin rears up front....... thatll flex like a champ!
2toyotas
this is the setup in my truck.
chevy 63's inboard about 6"  flexy as hell!
twistedtoy92
2toyotas
sorry but i dont. i took the truck out to test the suspention, everything worked as i wanted then i brought it back in the shop to rip the rest of the truck apart. i totally forgot to grab the camera. i suck
twistedtoy92
:pokinit:...... how much more flex would you say you have after inboarding the springs???
2toyotas
dont know, i went from 4" superlift springs in the factory spot to this so...no real way to tell
twistedtoy92
i see..... i need to look into this
2toyotas
are looking to do your springs inboard?
twistedtoy92
if it gains more flex!!!!!!
88_Pathy
twistedtoy92
how much??? if i ran a set of 63 inch chevies mounted 6 inches inboard with 6 inch shackles and johnny joints on the frame to shackle mount how well would that flex????
2toyotas
twistedtoy92
hell yeah!!!! Its goin on!!!
