front springs?
Started by kyle_22r, June 27, 2004, 08:36:41 PM
kyle_22r
any decent options out there for some low lift front packs that'll work with stock steering?  my fronts are negatively arched :crazy:  i'm looking for 1.5-2" of lift.  seems pretty simple, but...
...the only 2" fronts i could find are made by NWOR :smack:
are there any other options?  i figure i'll stay away from rears up front for now since i don't want to mess too much with my good old push pull box.  2" springs are all over for everything else, but they're impossible for me to find for a toyota
Thumper
Hey i suggest a set of super lift 3 inch springs, we have a toyota in our club that runs 3 inch springs all the way around and it flexes like crazy and he runs 33 ltb super swampers and that thing will go anywhere.
Its got a 3 inch superlift suspension lift welded front and rear 5.29's duel transfercases 20r motor and 33 ltb's and ive seen that thing go anywhere u point it it climbs and flex's like you would not belive.
still rides good and you dont need the drop steering arm.
kyle_22r
any other ideas?  i figure for the rears i can run 2wd springs that are good for an inch or two of lift...still boggled about what's a good low lift front spring though :dunno:
81Toy4x
Well I looked at the superlift 3" lift kits, and it says you get front 3" springs and either 2 1/2" blocks or 2" add a leafs.  Does your buddies truck actually have matching 3" springs, or did he get blocks or add-a-leafs.  I am really considering this kit.
84runner
It will come with blocks in the rear , my first superlift kit did
Jared
most lift kits kits come with blocks for the rear or add a leafs which are basically sh*t but the front springs usually come with new spring packs...my friend has a 4 inch superlift kit and hes jumped it about 4 or 5 times and it is still stiff as hell.  flexes like crap... i have rancho 305s on my front and a 3 inch aal in the rear and it is really soft.  it flexes pretty good but im definetly goin to rears up front and bronco IIs in the rear.
Thumper
81toyota4x
I really dont remember what his truck had in the back it may have the 2/1/2 inch blocks in rear because it flexs too good for add a leaf.
may have 3 inch springs thow dont remember its been awhile sence i saw it last he had been trying too sell it cuse of money probs but ill check and see.
adam
I think i have superlift 4 inch springs in front and they flex ok.  but shortly i will be going to rears up front for a LOT more flex.
donkeykong
Quote from: Thumper on June 27, 2004, 08:43:01 PM
If he welded the front He must have a hard time turning :screwy:
