30 spline long question
Started by COToy91, February 13, 2008, 01:15:37 AM
COToy91
If you replace the stock birfs and inners with this set up and grind for the clearance, can you still use the old birfs and inners as spares if you happened to break the 30 splines before a hub gear or R&P? I am just wondering if they would still slide in as spares  :headscratch:
GrenadedToy
if you can break a 30 spline longfield... then  :beerchug: to you
but to answer your question, yes. :biggthumpup:
i dig your truck btw
COToy91
Ha i doubt i could either but that you for the input. Thanks for the compliment grenadedtoy
Birfailed
Mmmkay.  Your stock birfs are all 27 spline at the actual birf.  the diff side is 30, the hub side is 30.  but the splines inside the birf bell are 27.
Go 1-Ton from the start
kiyul4130
Quote from: ColoradoToy91 on February 13, 2008, 01:15:37 AM
all your doing is clearencing the knuckle ball right? so why wouldnt they slide back in to the carrier and hub gears? yes. youll be fine.
-kiyul-
ECV 7-11
KYOTA FOREVER
COToy91
Thats what i thought but hey i doubt ill break them but better safe than sorry, i'm carrying spares
you have to carry extra inner 27 spline axles to if you want to use the stock birfs as spares.
COToy91
oh ya i understand that i would have to carry those to thanks a lot guys
