Did you build the dual cases or was it all reedy assembled? There should have been a hole to put a detente ball and spring on the top driver side . this pick is a MC07 but i think they would be in the same spot. take the bolt out and see if you have the ball and spring . If you do maby the shift rail got put in with the detentes facing the wrong way. if all that is good you need to call A/A
