Author Topic: t-case wont go into 4 low  (Read 3347 times)
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« on: Feb 03, 2008, 07:49:42 PM »
I have a gear driven 21 spline t-case  on my 93 toyota I put a 350 motor and a th350 trany to my t-case useing the adaptor that I bought I was told that I do not have to change the shift rails  I jacked the truck up and had all 4 tires off the ground I have use of 4 hi but not 4 low when I put it in 4 low it grinds its self out like you chant drive a 5 speed manual I cant figure out why I have 4 hi but not 4 low any ideas whould help  yes it is a fwd shift t-case the one that came stock in the 93 toy I already swaped the shifter out with a top shift shifter but I cant figure out why I cant get the darn thing to go into 4 low
IF YOUR LOOKING OUT THE FRONT OF YOUR 4X4 AND YOU CANT SEE THEN JUST TURN ON YOUR WIPERS. BUT THEN THINGS GET ALL MESSED UP LIKE IN LIFE.
WHEN YOU GET TO THE END OF YOUR ROPE JUST THINK THAT ALONG TIME AGO  YOU WERE THE FASTEST LITTLE SWIMMER TO THE EGG
08:55:22 PM BeccaLoo24 – i like to screw things
$99 scratch and dent drill press has drilled more holes than Ron Jeremy.
http://board.marlincrawler.com/index.php?topic=48342.0
[img]http://bo
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
Re: t-case wont go into 4 low
« Reply #1 on: Feb 03, 2008, 08:48:15 PM »
did the adapter have a hole to allow for the hi/low shift rod? and if not, did you cut it down?
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #2 on: Feb 04, 2008, 05:14:41 AM »
What he said
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #3 on: Feb 04, 2008, 06:02:19 AM »
I dont think so I drmember it had a square hole on top of the adaptor that you put the shifter into from the top
however the shift rails on my t-case were poking out the front and went through my adaptor my shift rails sit in the top of the adaptor and my old style shifter that I have will shift it into 4 hi but not 4 low
« Last Edit: Feb 04, 2008, 06:19:16 AM by maxwe001 »
[img]http://bo
*ROKTOY*
  • Male Posts: 1,066
« Reply #4 on: Feb 04, 2008, 07:46:56 AM »
PIC'S Needed
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • SimpsonBrothers.net
« Reply #5 on: Feb 04, 2008, 07:53:18 AM »
I think this is the adapter, it does appear to have holes for the shift rails
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #6 on: Feb 04, 2008, 09:32:39 AM »
yes thatis the adaptor and the shift rales are covered up in that pict but YES that is the adaptor i have
[img]http://bo
MiniSimp
  • Male Posts: 5,120
« Reply #7 on: Feb 04, 2008, 09:35:07 AM »
Is there any chance that your shifter is hitting your body?
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #8 on: Feb 04, 2008, 09:38:11 AM »
no
[img]http://bo
kvn85
  • Turtle Points: -84
  • Male Posts: 90
  • Member since Aug '04
« Reply #9 on: Feb 04, 2008, 10:33:02 AM »
You should call Advance Adapters.
85 yota
*ROKTOY*
  • Male Posts: 1,066
« Reply #10 on: Feb 04, 2008, 12:14:07 PM »
You could try removing the shifter and try putting it in 4lo by hand see if that works, I'm thinking there maybe some interference there or your shifter is not in properly. Another thing did you take the tcase apart and mabe forget the interlock pin?
« Last Edit: Feb 04, 2008, 12:21:10 PM by toyguy86 »
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #11 on: Feb 04, 2008, 01:04:16 PM »
I did what advanced adaptors told me to do and that was to mount the adaptor to the t-case thewn the whole unit t-case and adaptor to the trany use exsisting bolt holes that the t-case used /NO I did not take my t-case apart and look for a interlock pin advanced adaptors did say anything about taking the t-case apart and removing a interlock pin. I did what they told me to do
[img]http://bo
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #12 on: Feb 04, 2008, 01:10:01 PM »
unless you are twin sticked, you don't mess with the interlock pin.  it really sounds like the hi/low shift rod isn't moving all the way forward.  If you did not disassemble the case at all, and you are sure the shifter isn't hitting anything, you need to call AA.
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #13 on: Feb 04, 2008, 01:15:05 PM »
I can hear it grinding the gears in 4 low and I know this cant be good so I put it back in netural on the t-case
do I have to have the trany in netural as well or can it be in drive with the break on or can I have it in park  or does it just got to be in netural to go into 4 low
[img]http://bo
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #14 on: Feb 04, 2008, 01:19:00 PM »
it should shift into low in any gear...
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #15 on: Feb 04, 2008, 01:20:54 PM »
ok I just found the reciept from where I bought it and the part number is on it and here is the part number 50-5702 advanced adaptors
[img]http://bo
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #16 on: Feb 04, 2008, 01:48:20 PM »
just got off the phone with A.A . and he told me that I didnt need to change the shift rails or anything but I could take the shifter off and manualy put it in 4 low and try it that way and see it it goes that way  now all I gota find out is what shift rail works the hi low side is it the one on the left or the right ???
[img]http://bo
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #17 on: Feb 04, 2008, 07:05:49 PM »
:_oops:
I just realized it's not the hi/lo rod, the one that moves forward is the 2/4 shift rod.  it is on the right hand side, looking down from the top.  it is the one that moves out of the tcase for engagement.  the hi/lo is actually the left rod, and moves backward to go into low. sorry. I would still pull it and verify that everything works fine out of the truck.
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #18 on: Feb 05, 2008, 06:45:02 AM »
ok I pulled the shifter out and I manualy put it in the gear i did both shift rails independantly of each other  but now you tell me that both of the rails have to be all the way back for it to be in 4 low :dunno:
[img]http://bo
MiniSimp
  • Male Posts: 5,120
« Reply #19 on: Feb 05, 2008, 06:55:49 AM »
Well, you go down to go in to 4wd (right shift rail moves forward) then over to the right (stick moves to left shift rail) then forward one click to neutral (left shift rail moves back) then forward another click for 4 low (left shift rail moves back more). So then, with the right shift rail all the way forward, and the left shift rail all the way back, that should be 4 low. Unless I'm all fucked up. :headscratch:
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #20 on: Feb 05, 2008, 07:21:18 AM »
so the one on the left (driver side) is all the way fwd. and the one on the right(pass. side) is all the way back  :headscratch:  and that puts it in 4 low?
[img]http://bo
MiniSimp
  • Male Posts: 5,120
« Reply #21 on: Feb 05, 2008, 07:57:54 AM »
I think so, I use a twin stick, so I'm not entirely sure, it's been a while since I used a regular shifter. Duffil will be able to say for sure.
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #22 on: Feb 05, 2008, 01:52:34 PM »
no, the rail on the pass side should be all the way forward and the drivers rail is all the way back.  Minisimp is correct above.  You have to remember that the shifter pivots at a midway point, making everything under the pivot the reverse of the knob position.
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #23 on: Feb 05, 2008, 01:56:33 PM »
so when I manualy put it in 4 low the pass side will be all the way to the front of the truck and the drivers side should be all the way back towards the tail gate correct?
[img]http://bo
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #24 on: Feb 05, 2008, 01:57:25 PM »
yes.
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #25 on: Feb 05, 2008, 01:59:48 PM »
ok I will try this and see if i can get it to go either tonight if the rain holds off  other wise I will have to tryit tomarrow afternoon
[img]http://bo
MiniSimp
  • Male Posts: 5,120
« Reply #26 on: Feb 05, 2008, 02:04:07 PM »
...if the rain holds off...
It rains inside your cab? :headscratch:
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #27 on: Feb 05, 2008, 02:11:20 PM »
if i leave the sun roof open it does  :yupyup: but I gota have power to see and the extention cord will get wet and I dont like to use the water eletrical mixture to well while it is lightening outside or else i might look like this  :shocking:
[img]http://bo
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #28 on: Feb 06, 2008, 08:09:01 AM »
update: I got the shift rods to go all the way into 4 low and it didnt grind or anything so there for it is in my shfter itself, The shifter is stopping before the gear is fully in 4 low I guess the could be due to the fact that the old style shifter that I have the ball the rotates around is not as big/ (have as much movement) as the stock shifter??? I had so I gota figure out why its not putting it all the way in gear any ideas??? I might have to weld a small joint around the stub the moves the gears in and out unless you have a better idea???
[img]http://bo
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #29 on: Feb 06, 2008, 01:00:47 PM »
I've only seen one style of tcase shifter on the bottom.  What I mean is, from the ball down they are all the same.
Last post Nov 14, 2003, 10:51:00 AM
by 95TacoTruck
Wont run right Help!
Last post May 28, 2005, 08:19:39 AM
by Uncle Jesse
Last post Sep 12, 2005, 06:14:38 PM
by Remotruker
Last post Nov 19, 2005, 12:46:58 PM
by kneedownnate
Last post May 10, 2006, 05:36:09 PM
by kneedownnate
