Selling 3 different diffs but I need to keep one of the 3.
Elocker with 5.29s solid spacer. Will include inchworm wiring kit. Gears were set up by ZUK at
www.gearinstalls.com Yukon gears and bearings were used. Always used synthetic gear lube. Probably around 1500-2000 miles on set up and changed gear oil a half dozen times. Here is the link
http://www.gearinstalls.com/elocker200.htmBroke the electric motor on a rock. Still works just exposed to the elements. Picked up another motor from the yard it worked for about 2 weeks. I took it apart and it was rusted. But can make a good motor out of the 2.
Marlin sells for $1300 plus shipping
Ill sell for $750 or $800 with an other used elocker motor from the yard.
The other diff is A V6
Upgrade for 4cyl V6 diff (larger bearings)
Housing sand blasted and painted
trail gear v6 5.29s
Trail gear v6 spool
New timkin bearings
New dust shield and pinion seal
TG solid spacer
Everything new Never ran, pattern check by a L1 certified tech.
Trail gears gets $800, Ill sell for $600 obo
Lastly a another V6 Diff
solid spacer
lock-rite
yukon 5.29s
used in front axles so it doesn't have much use.
Zuk also set up this diff.
Marlin sells for $1,044 plus shipping, I'm looking for 700
mkmarz@comcast.net
located in millville ma 01529
