just my luck
Started by Skinny_Pedal, June 16, 2004, 08:27:54 PM
Skinny_Pedal
i went wheeling today with prism and 81toy4x and we had a blast. prism was showing us how the older guys do it and it was awesome. so then we were on the last trail of the day and it was kickass, yet again thanks to prism for that sweet trail. anyway nick(81toy4x) was in path the i wanted to take and wasn't gonna be moving antime soon because he didnt want his truck to get dominated by a tree. so prism was like take this route and i went for it. i go through the puddle and i must have hit a log or something and right when i did, there was a funky sound. a clanking sound i would call it. and it only makes the sound when the hubs are lock, doesnt matter if its in 4wd or 2wd. the sound is also coming from the front end. so my question is does anyone have an idea of what this sound is coming from. i know i didnt give a good description but thats all i can give right now, any help would be appreciated. im gonna get it on the lift tomarrow at school to c if i can figure anything out, but u guys always seem to have a good idea as well.
Im an OG
Its probobly either the ring & pinion or the spiders.  Those parts seem to scatter easily.
Skinny_Pedal
u think, thats gonna suck if its true. prism seemed to think a cv but both hubs need to be locked for the sound to happen?
Im an OG
The cv's are really easy to kill too.  Just try the old shake and twist method.  If you feel more than 1/8" movemont in any direction then its toast.
Skinny_Pedal
ok ill go do that as we speak. i swear wt u are my hero these days. i just hope prism doesnt give u such a hard time this weekend at goldendale
Im an OG
No worries is he smarts off too bad Ill just slash the tires on his rascal scooter!
Skinny_Pedal
ouch! anyway i just went to my truck and it feels like my passenger cv is a little  losser than my driver side. but ill just get it on the lift tomarrow and have the front wheels spinning and c if i can figure out whats going on.
Im an OG
lock the hubs and put the t-case in 2wheel.  See what happens when you try and turn the driveline.  Then unlock one hub at a time and spin the driveline.  See what happens, that will tell you what the issue is and where its at pretty quickly.
Skinny_Pedal
well what do u think i should be looking for or i guess listening for if it is the rin and pinion or spider gears?
Im an OG
I would think it could be something in the hubs if it does it in 2wd also.  I am just thinking though and that's not good at times.  Do you have a front locker?
Remove your rear driveline, put the front up on jack stands, pull your e-brake, fire it up, and let it idle in 4WD high 1st gear or so with both hubs locked.
You could shift it into Low and use first gear, and then while it is idling in 1st, use your hands and slowly stop on of the tires. The other will spin twice as fast, but doing this will stop the axle and you can see if the noise goes away. Do the same to the other side also. If the noise is still there both times, then its in your diff-
Prismo
#11
No he most assuredly does not have a locker. I may have a set of 4.10 stock 7.5" gears in the shed
Skinny_Pedal
prism i just hope it doesnt come to that. but ill be sure to do these things tomarrow and let u all know what is going on so u guys can all further help me because right now im :headscratch:
Im an OG
Prismo
Let me know if it is the gears & will look tommorow to see if I still have them. We are not leaving until Friday now.
Skinny_Pedal
#14
o ok, ill give the post up tomarrow for sure.
Im an OG
yotasrockontherock
ive got a set of 4.10s from my 85 that i could sell for cheap if you need them there still in great shape and has the bearings and everything
85 4runner 5.29s 31x10.50s sr5 2inch shackels
Unfortunately he still has Inferior F#$king Suspension so they wont work.  But that is a nice offer reguardless  :thumbs:
derek
if its the gears i think 82yotacrawler had an ifs third he was giving away.
may want to see if he still has it.
derek
Skinny_Pedal
 :smack:, no wt- ifs stands for  it flexes sweet. ill let it slide this time though ok. i was also late to class today so i couldnt get it on the lift, ill try tomarrow
Im an OG
Bazzi
sound to me that it is the ring or pinion. you could try to lock the hubs and move the wheel while moving if the sound is always the same it should be the ring or pinion.
yotaboy79
sounds like we have the same kinda luck :shake_head: good luck ill keep a look out for ifs gears
Skinny_Pedal
i got a guy that will sell me the front diff and cv axles for $150, but i still just want to know what it is.
Im an OG
Skinny_Pedal
ok well i got it on the lift today and you wouldn't believe it. it was the cover on the front driveshaft, the cpver that covers the u-joint. it had got pinched up and made that annoying noise. so its fixed and there are no worries. thnaks for all your inputs.
Im an OG
Jared
thanks derek....  :beerchug: im still trying to get rid of that damn difff.... :maddest:
Skinny_Pedal
Im an OG
Jared
my buddy did sas on his 4runner he still had everything and he was throwing it away so i just took it from him incase anyone needed it...
Skinny_Pedal
well if by take it u mean free! send it my way
Im an OG
84runner
Glad to hear thats all it was, :yupyup: SWEET
That cv joint cover is a road kill gaurd.
