Transmission breather?
Started by robinhood4x4, June 13, 2004, 10:26:02 PM
robinhood4x4
Does the auto tranny on the 2nd gen 4runners ( I think its the A340H) have a breather?  I found and extended the transfer case one, but can't find anything for the tranny itself.
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
I cant guarantee it but I pulled a auto out of a 85 a few weeks ago and the breather was coming out of the top front of the trans.  It had a breather that would basically rest on the back of the head on a re.
Prismo
The A340H has a breather tube at the top of the tranny behind the bell housing.
robinhood4x4
Ok.  So this breather is just like all the other ones with the little one way valve thing, right?  No hose?  I hear some jeep trannies are just open to the air.  A guy in my club sucked in a lot of mud to his wrangler tranny.
It has a breather that is on the end of a hose.  On the 85 the hose was about 8" long
robinhood4x4
SWAMPER
 :o  O o what happens if you get a lil water or mud in the tranny...will it show up when you check the dipstick? :ack:
If you get water in an auto ithe fluid will look like pepto bismol.
SWAMPER
Good Job LilSwamper has held up then :biggthumpup:....if that were to happen what would have to be done in order to have it back to normal? :headscratch:
robinhood4x4
#9
Do a complete flush (about 15 qts) and start saving up for a new tranny.  At that point it might last a week or it might last for another 10 years.  It depends on how much damage was done and you can only tell if you take apart the tranny.
Edit:  of course I'm posting this on a transmission guru's forum and I'm no expert, so... :twocents:
SWAMPER
Gosh and nothing would happen if I extended the breathers right...just like the diff breathers
