Author Topic: Number 2&3 Intake Rocker Shaft Spacer  (Read 1500 times)
RynothealbinO
  • Turtle Points: -15
  • Male Posts: 141
  • Member since Aug '06
  • 36's on no lift!
« on: Dec 31, 2007, 10:05:21 AM »
Does anyone know where I can get the rocker shaft spacers for a toyota 22r.  If you don't know what I am talking about it is a plastic spacer that is supposed to push the number 2&3 intake rockers over the valve stem to keep them in allighnment.  Mine are worn to the point that the adjusters are more than half way off the valve stems.  The only ones I can find are from Toyota and they are in California, which means they are a week away for me because I am in Minnesota.  Or can i just cut a spacer for the spacer out of a second worn out one?  Any help is greatly appreciated because I need to have this thing running by the weekend.
Trust in the LORD with all your heart and lean not on your own understanding, in all your ways acknowledge him and he will make your paths straight.  Proverbs 3:5-6  Don't let anyone look down on you because you are young, but set an example for the believers in speech, in life, in love and in purity.  1 Timothy 4:12
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Number 2&3 Intake Rocker Shaft Spacer
« Reply #1 on: Dec 31, 2007, 04:46:38 PM »
the spacers on a 20R  are metal  and the same size,  you should be able  to find them in any  junkyard engine
RynothealbinO [OP]
  • Male Posts: 141
  • 36's on no lift!
« Reply #2 on: Jan 01, 2008, 03:07:19 PM »
Thanks Glenn, too late though because I went ahead and bought ones from Toyota...so I geuss I will have to wait to get the truck going.  But I have to wonder, why are these so hard to get ahold of?  Do they just rarely wear out or are people in other parts of the country just able to get ahold of them?
RN37DD
  • Male Posts: 742
  • Member since Apr '07
« Reply #3 on: Jan 01, 2008, 04:51:01 PM »
all the early 22r's I've had used metal spacers. even a rebuild time .. zero wear. i wonder if most of the guys with real late model 22r's even look at their valve train. :dunno:
RynothealbinO [OP]
  • Male Posts: 141
  • 36's on no lift!
« Reply #4 on: Jan 02, 2008, 09:04:27 AM »
I know I never did until after adjusting the valves many times, changing the timing chain, and I finally noticed this at the vary end of a complete engine rebuild.  I wonder I Toyota is sending me the plastic ones or the metal ones?  I read somewhere that Toyota makes a two piece one that clamps on and allows you to simply cut the old one out and put the new one in place without removing the head bolts, which would mean you should also pull the head to replace the head gasket.  Does anybody know anything about these supposed two piece replacements?
RN37DD
  • Male Posts: 742
« Reply #5 on: Jan 02, 2008, 05:00:09 PM »
I haven't done it myself. but a few guys have removed the headbolts and rockers to change cams with out replacing the head gasket. guess ya just got to drain the water and be very careful not to brake the gasket loose.
« Reply #6 on: Jan 02, 2008, 06:39:44 PM »
in theory  you could just remove the  front 2  head bolts  then  slide  the  rocker  shaft  out
but  i would just remove it  and  replace it on the bench
Last post May 15, 2004, 10:28:07 PM
by Marlin
Last post Apr 18, 2006, 08:50:58 AM
by 84_yota_4wd
Last post Jun 10, 2006, 06:44:04 PM
by 79coyotefrg
Last post Jun 12, 2007, 09:26:59 AM
by Tallchevy
Last post Oct 18, 2007, 12:14:34 PM
by DTB
