there is a screw plug that hides it that needs to be drilled out.how is the engine compression? black smoke usually means oil
Check all of your vacuum hoses for cracks and leaks and also make sure there hooked up properly, check the aap diaphragm and also check your timing, all of these can cause the problems your having.
Started by croberts Toyota Pickup/4Runner Tech 1979-95
Started by auckman Toyota Pickup/4Runner Tech 1979-95
Started by 79yoda Engine
Started by I.D.G.A.F Engine
Started by motoracer « 1 2 » Toyota Pickup/4Runner Tech 1979-95
