Transfer Case Problems - Questions
Started by blackdiamond, December 24, 2007, 06:20:04 PM
blackdiamond
I'm running a Marlin Crawler dual ultimate that has an 85 rear case and an 89 front case.
A few months ago the needle bearing on the countershaft in the front case failed and brought me to a screeching halt.  The front case was rebuilt and this weekend it seemingly had another failure in the front case.  Both times the rear tires ended up locking, on dirt the first time and on wet pavement the second.  The first time the front case got extremely hot, but the 2nd it was warmer than the other drivetrain parts, but I could put my hand on it easily.
Are there any compatability issues with front and rear cases?
Any ideas for what is causing the failure?
:help:
all i can think of  is  installer error  or  bad bearings,   did gotrocks install them ??   im sure  he  knew  what to do  so  i would wonder  if  you had  enough lube in the front case
did you dump a qt  in the front case when you filled them ??
blackdiamond
gotrocks and snowrunner (?) did the installed the front case on my Marlin 4.70 case and I had a local shop do the rebuild after the bearing failure.  I changed the fluid via the front shifter until it ran out of the fill hole in the rear case.
I'm hopeful that the failure mechanism is obvious when they get it torn apart.
MiniSimp
Sounds like no grease used on the needle bearings, I'm sure the oil should lube it enough, but I like mine heavily coated.
When I broke down my cases after 3 years there was still grease covering every part.
Have you checked to see if the shaft is true?
blackdiamond
The verdict from the shop is that the needle bearing failed again.  They had already talked with Marlin Crawler and the parts were on the way under warranty.  I'm across the country so I don't have any other details.
gotrocks
Quote from: MiniSimp on December 27, 2007, 06:35:45 AM
Why would you have grease in your t-case?
blackdiamond
So the question is if not using the grease during install would result in bearing failure?  :dunno:
MiniSimp
Quote from: blackdiamond on December 28, 2007, 08:53:19 AM
No idea.
I just grease the hell out of all my parts from habbit.
blackdiamond
I called Marlin Crawler about this and was told it would cause premature wear but couldn't say how much it would be expected to shorten the life of the bearing.
I'm sure the shop used grease since it is included on both the Marlin Crawler and Trail Gear assembly instructions online.  I'm not sure which set I printed for them last time, but they have the Trail Gear stuff this time for reference because the pictures are larger.
Quote from: gotrocks on December 27, 2007, 10:48:04 PM
your supposed to put grease  on them  so they dont fail  when  the first start  running
blackdiamond
Since I didn't assemble the dual crawler, does the dual adapter bolt directly on the rear case or is there some dissembly required on the rear case?
the rear case bolts to the adapter  just like it will the transmission
blackdiamond
Quote from: 79coyotefrg on January 08, 2008, 02:40:06 PM
So in the standard configuration the gear oil in the transfer case goes up to the rear of the transmission?  This is why the front and rear cases share oil?
gotrocks
Yes.
BTW I talked to snowrunner and the original bearings were greased when installed. So I have no idea why the first one failed and even less of an idea why it failed you again.  I hope they find something because I know it was done right on this end.
#15
Regarding the pre-assembly grease, it is not going to make or break anything. It is not going to cause "Excessive wear" and I certainly would never loose any sleep over it, especially with something so primitive as the gear drive t/case.
Question: What serial # is your dual case adapter please?
Thanks,
EDIT: Fixed a grammar mistake :smack:
blackdiamond
Quote from: BigMike on February 17, 2008, 05:13:48 PM
Regarding the pre-assembly grease, it is not going to make or break anything. It is not going to cause "Excessive wear" and I certainly would never loose any sleep over it, especially with someone so primitive as the gear drive t/case.
Thanks,
#3455
gotrocks
Thank you for saying this.  I didn't think I was crazy when I wrote my earlier comment about grease.  It just doesn't seem like it would be such a crucial thing to cause a premature failure.
"someone" .... whoops ha ha :ha_ha:
BD: I will try to get back at this tomorrow, sorry it is a mad house at the shop with the convention this weekend.
Thanks
Duffil
[threadjack] what convention Mike?[/threadjack]
