Ebay 22r performance cam??
Started by Jared, June 09, 2004, 12:40:47 AM
Jared
has anyone ever tried this cam?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33614&item=2481211389&rd=1&ssPageName=WDVW
Should i get his or should i just bite the bullet and get a lc or a downey or a trd cam?
Jared
if i do get this do you guys recommend it for daily driving in cali???
kyle_22r
i'm not sure about that one, but i see engnbldr cams on there every now and then.  supposedly those are the best bang for the buck(they only retail for $89 or $99 new anyway)
84runner
You need to find out if the cam is smog legal cause you live in CA this could cause a major problem
BLUCRUZ
I would buy from www.engnbldr.com, I use his 270 cam in cali
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
looks like about the same cam,  a .430 lift is a good torque improvemnt over stock,   $100   isnt bad
but you do need a CARB ## for cali
brainlessfool
Will more than likly pass smog, just don't tell it in there. and run your idle about 1K rpms.  I pass smog with my cam, my cam specks are
                           I-- 214 dr. 416 lift
                           Ext--224 dr.  430 lift
                      cost about $100 at NAPA.
84runner
You don't need a VIN for a cam as long as it will pass out the pipe, they will never know it's in there
