Any ideas on how to fix this?
Started by CGuava, June 08, 2004, 11:44:57 PM
CGuava
Or should i just get a new tranny?  Thanks in advance!
That's the back end of the tranny, just got my duals in, went to moab, started leaking, came back to find this.
Any help is greatly appreciated.
Thanks,
Christian
PS:  I know about the wood, please....it's been a long day.
88 Runner, SAS, Duals, Locked, MT/R's, Bilsteins, Toobed.  The usual stuff.
Jared
a good coat of JB WELD shouldnt hurt..... :biggthumpup:
Jumped one to many dunes...
Good luck if you are going to repair that. I wouldn't want to.. and replacing the tail housing is a job.
Beings you have decent access to the break Id clean it with brake clean then make a jig to hold the piece in place.  (think multiple c-clamps)  Id then drill it in at least 2 direction 1 hole going up the other going horizontal.  Then when I Jb'ed it Id have the pins in place to reinforce the break so hopefully it'll never come apart.
84runner
You can clean it up real well then V-goove it and weld it up with a couple passes.  I have done it before on cast aluminum parts. If it's done right it will hold up  :thumbs:
You guys aren't serious are you? JB weld on structural housings? Joking right?
Jared
I was actuallty gonna use duct tape...   :slap:
yotaboy79
where you at if you bring it to me ill be nice and tig it for you then grind it down flush and smothe or take it to a fab shop or somthin and have them do it
Prismo
Quote from: yotaboy79 on June 09, 2004, 03:43:33 PM
Welding would work. The tranny to transfer mating surface would have to be real close to true or it could break again.
toyhatsu
The last time that I was at a friends welding shop he had just bought a spool gun.  We took a cast aluminum electrical housing about 1/4" thick and cut it in half on the band saw.  He welded it back together with the spool gun, put the welded piece in a heavy bench vise and handed me a 10 lb. sledge.  I finally got it to break but not at the weld :_order:.  If it were me I would try the welding first.
1991 Daihatsu Rocky, 3RZ-fe, Marlin super heavey duty clutch and pressure plate, Marlin W56-C-HD, duals, Marlin twinstick, three link front with Fox AirShox, 35's, Toy axles, 5.29:1, ARB F&R etc.
if it were  here i would send you to Whisenhunt Welding,  he's been welding AL-U-MIN-EUM,
for over 15years  he welded a   caddy block once and i couldnt tell were the weld was after he was done finishing it
any reputable welding shop,  that can do TIG welding can fix you up but make sure they have experience with aluminum
CGuava
Are these places out west?  I'm over here in Denver so i'll have to try someone here, but thanks, i think i know just who to ask to TIG it for me.
Christian
84runner
Wire feed aluminum gun would work just fine too. Again , I wold go to a local college if you can't find anyone to do it and speak to the welding instructor  :yupyup:
81Toy4x
Quote from: BigMike on June 09, 2004, 12:56:56 PM
BigMike, I don't think they were joking.  I have seen people use JB weld on engine blocks.  I have actually repaired a break on my transmission before with JB weld.  It might sound like a joke, but it works.  Guys have repaired the blocks of engines on huge farm tractors.  It's amazing stuff.
84runner
Ya but thats a more get you home fix than load it up and take it to the con
I once JB welded a vaccumm solinoid's little plastic tube and the weight of the attached rubber vaccumm hose broke it off in about a week..
A solinoid like this one:
I havnt used JB for anything else though, so that makes me a bigot  :headshake:
Bazzi
you shuld go to a proffesional  welder and see what his sugestion is  or replace it
yotaboy79
our boad had a big!!!!!!!!!!! crack in the block and jb weld fixed it
Skinny_Pedal
81toy4x what truck needed the jb weld fix?
Im an OG
Crazy glue!!!!!!!!!!!!!!!!!!!!!!!
84runner
Whats your location CGuava ? Are you in CA ?
CGuava
84Runner, i'm in Denver.
Christian
84runner
Hmm well thats a long way for me to go toweld that up 4 you
Quote from: Hyena on June 10, 2004, 08:39:06 PM
oh man  :smack:
yea 84runner is right,  a wire feed welder will do just as good as long as its has aluminum wire in it :driving:
#25
And youll need at least stargon of not straight argon for it to work good.
CGuava
hehe, yeah that's true, it's a loooooong way, but thanks for the offer.
Christian
