85 4runner!!
Started by yotasrockontherock, June 06, 2004, 01:17:47 PM
yotasrockontherock
hey huys just looked at the 4runner sr5 today and im picking it up tomorrow its real clean here is whats on it its got a sun roof a/c, p/w, p/s, and a tilt wheel its got 5.29 gears and a new efi four banger out of a 94 4x2 truck with only 109k on that engine its got a centerforce dual friction clutch new bearings in the axles so its pretty much a new axle the raiido dosent work but thats ok cuz i got my brothers old one and this thing is sick ive got a pic of it but its jpeg and i dont know how to make it jpg so i can put it on here so if someone wants i can send it to them and have them post it for me and im getting shackels sometime this week for it so that will give it about a two inch lift and its got 31s on it right now  :yupyup:  :driving:
85 4runner 5.29s 31x10.50s sr5 2inch shackels
yotaboy79
nice, if you want you can e-mail me the pic and ill fix it for ya my e-mail is [email protected]
88runner
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
yotasrockontherock
yotaboy79
ok here ya go, there was nothing wrong with it it was the right format and size  :dunno: here ya go
KYOTA
That almost looks too nice to build on.
Na- cutter up :flamer:
yotasrockontherock
hummm thats weird cuz when i tired it, it would'nt let me but thanks for posting it and yeah its a nice truck the trans and transfercase have 260k on it though but it dosent look it at all its got lots of power too with the 5.29s
84runner
yotasrockontherock
been working on it today and dribing it around the yard and its puttin out some white smoke dose anyone know why this is and how i can fix it thanks
Could be the headgasket or just condensation.  Let it run for about half an hour and see if the steam quits
yotasrockontherock
ok thanks ill go do that now and it could be condisation cuz it drips and also it wont start unless i give it a little bit of gas i was thinking it could be from when they put the new engine in they didnt put something back right that makes it fire right up
yotasrockontherock
ok well its been runing for about ten minutes and it has seemed to have cleared up it still dose it when i rev it up about four time in a row but b4 it did if i just reved it once and the guy who had it b4 me just let it sit in the garage for two years i hope it isnt the head gasget
Quote from: yotasrockontherock on June 06, 2004, 01:17:47 PM
Ok, I've added files with extension .jpeg for uploading.  :_oops:
youll have to DRIVE it for about 10 minutes to get the exhaust up to opperating temp, just putting around the yard or letting it idle wont get the exhaust pipe hot enough to burn the water out of the pipe.
yotasrockontherock
well i would but i dont have plates for it yet and wont have them till the 21st so i dunno
what do plates have to do with driving a rig?  Ok ill let ya slide with it this time, but plates dont stop me from driving a rig ;)
yotasrockontherock
yeah well it wouldnt stop me either but i dont have my licence yet and my mom thinks there are cops everywhere even up here in the moutains were i never see any in my nehiborhood and if i drive it with out her letting me i will never get my licence so i would never get to drive it
Well its a good idea to listen to your parents on stuff like this even though I didnt.  I should have it would have saved me a few headaches back then.
yotasrockontherock
yeah same with me i would have gotten my licence back in april instead of the 21st of this month but im still wondering why it wont fire right up when i turn the key like my brothers 89
Its called the black goo.  It gets in your intake plenum and causes hard starting and sluggish performance.  You have to take the intake manifold off of the rig to clean it but its worth it!  Considering the miles your rig has on it Id just about guarantee that is at least part of the problem.
yotasrockontherock
yeah well the truck has 260 on it and the new motor only has 109 on it
yotasrockontherock
is that an easy job to take it off and what kind of tools do you need to do so
84runner
It's an easy job really but you do have an allen screw towrds the fron passenger side of the intake that you have to pull out along with the intake bolts or it will never come off. the bolt is about 4 inches long
yotasrockontherock
ok well i just got from a drive with it and its still smoking and it smells like oil so dose that mean ill have to get a new head gasget  and again is that hard and or there any speical tools needed and could it have anything to do with the valves cuz my dad did say id probally have to get a valve job on it  :smack: :dunno:
yotaboy79
check your water level if it whent downt then your head gasket is prolly blown or your leaking somwhere else
yotasrockontherock
yotasrockontherock
could the fuel filter have anything to do with the truck not starting with out me giveing it gas? and if so isnt it located on the frame and they smoking did go away but it still kina stinks
Yes the filter could give you some grief in starting.  Its under the intake manifold.  The easiest way to get it is to take the passenger front tire off and pull the rubber skirting away from the body there should be a access panel that bolts on the inner fender.  Take that panel off and the filter is right inside bolted to the block.  Yes the job sucks but you dont have to replace the filter very often though.
yotasrockontherock
ok well my dad just had a talk with the guy we bought it from and he said he got the fuel filter replaced when he put then new motor in and that was only 9k ago but he said he had the same promblems with starting and he took it in and the cold start injector work iraticly which makes sence becuase when i went to start it up this morning it didnt trun over for about 5 minutes of on and of cranking but once i finaly got it started up and i let it warm up for about 5 mins and then i turned it off and tired it again and it started right up with no use of the throtel and it still kinda smokes a bit but its only when its warm which makes since for the condisation and wt is the fuel filter on a 91 4runner 4cyl in the same place? :dunno:
84runner
What color is the smoke and what does it smell like ?
