There's a couple of 'not used' connectors (common wiring harness for different needs) so are you sure it's the correct wire?
X 2 and where are these spare wires located? can you post pics for referance? Did you run codes?DanS
what do you mean by NOX sensor? NOx is Oxides of Nitrogen, and only come into play with SMOG terminology. You DO, however, have an O2 (oxygen) sensor in your exhaust, and a KNOCK sensor in the engine. Which do you mean?
Started by ezthere Engine
Started by GoaT Engine
Started by havik Parts Wanted
Started by Caboose Toyota Pickup/4Runner Tech 1979-95
Started by jeff94runner Toyota Pickup/4Runner Tech 1979-95
